Wireless g wrt54g router
I have a problem keeping a connection to the internet, using a wireless g broadband router. I hook in into a pc using windows vista, and wirelessly to a mac, and everything is fine untill the next day the the pc dont find the router or the internet. Any clue what is wrong? thanks steve
  • 1 more comment
  • fritz67337 Feb 25, 2008
    im connecting to a pc. The problem happened three days in a row . Every time it happened i uninstalled the router so i could reconnect with a wired connection. Dont have a clue what is going on. I Installed the program just as it said, but every morning it pops up as not dectecting the router. The pc has the router connected to it through a wired connection and the mac is wireless.any suggestions?
    router is not detected by pc next morning, i tried the latte ... didnt seem to do any good.
    drivers are compatible i asume it works fine all day untill the next morning, like maybe going into hibernation has some effect on it ??? Clueless
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    sure..could be a power glitch..the mac could be invading the pc through the router, and disabling the IP connection(NOT)..
    is the router still functioning next morning? Try serving a latte, perhaps?
    I'm assuming you have new vista compatible drivers for router, yes?
    Scholar:
  • 117 Answers
First of all, are you connecting with a PC or a Notebook?
If you have the Linksys router, you should replace the MS utility with the Linksys utility it figures your linksys wireless lan card
There are programs you can use to keep track of your router and connections...One such program is called Port Mapper...
http://3d2f.com/programs/34-197-port-mapper-download.shtml
Does your problem happen everday...or every 3 weeks...are you doing anything in particular when you are getting the inability to use the connection?
There is a new Vista patch out there I recommend downloading.
Posted on Feb 24, 2008
  • Terry Lynn Deschamps
    Terry Lynn Deschamps Feb 25, 2008
    One suggestion would be to hard wire the mac...and go wireless with the pc...Although there are those who love Macs...sometimes Macs do have glitches with wireless..(as do PC's) LOL i'll say that for those MAC die hards..
    Switch out the NIC card on the PC and give the Mac the hardware...and give the PC the wireless...
Wireless 2.4ghz router for wifi
Wrt54g can be used as either a wireless router or access point. I am not familiar with your broadband service, but if it has a data port just connect it to Internet port.
Nov 02, 2017 | Linksys Wireless-g 2.4 Ghz Broadband...
Tip
Full details on how to set up your Wireless-G WRT54G Router
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at
the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network.
Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other
end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a
standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical
outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result
in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each
other across a network, such as the Internet.
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router.
The next few pages tell you, step by step, how to configure your network settings based on the type of Windows
operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network
adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/IP line for the applicable Ethernet adapter.9641e30.jpg
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
itself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.a443500.jpg
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart
your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area
Connection listed). Double-click the Local Area Connection. Click the Properties button.ea4fa3a.jpg
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the
Classic interface (where the icons and menus look like previous Windows versions), please follow the
instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon.
Then click the Network Connections icon.
Connection listed). Double-click the Local Area Connection. Click the Properties button.f2e300e.jpg
button. Click the OK button again to complete the PC configuration.
If you would like more information on setting up your connection, please ask me a question.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
on Jun 28, 2008 | Linksys Wireless-G WRT54G Router
My niece gave me a Linksys WRT54G wireless broadband router. But she couldn't find the installer. How do I install it to my computer?
1)Connect lan cable on any of the port in router and connect your pc? And check whether your pc is getting automatic ip and check what is the gateway defined there??And just put that ip(if default it will be 192.168.1.1) in your internet explorer and access your router.
2) If even connecting your pc its not getting any ip then reset you wireless router and login using internet explore 192.168.1.1 ip?
Sep 22, 2010 | Linksys Wireless-G WRT54G Router
Cant hook up my wireless internet card to my wireless g router
you can connect your huawei card to your computer usb port then install driver then you can use it.
Jul 28, 2009 | Linksys Wireless-G Broadband Router
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
Wireless connection is not secure when I'm logged in from PC,anyone can use
Click on this link
http://www.portforward.com/english/routers/wireless/routerindex.htm
Then choose the brand and model of the router and follow the steps how to secure your wireless connection.
Sep 24, 2008 | Linksys Wireless-G WRT54G Router
My laptop is not working
you mean not working wirelessly? please elaborate so we can help.. :-)
Jul 14, 2008 | Linksys Wireless-G WRT54G Router
I have a desk top hook to the router now i need to hook my laptop to have the enternet
in product damage.
Overview
the Router.
Connections icon.
Jun 27, 2008 | Linksys Wireless-G WRT54G Router
Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Mar 14, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
95 people viewed this question
Alun Cox
David Payne
David Payne
