Question about Zanussi ZWF1430W Front Load Washer
Zanussi zwf 1432 w washing machine
I have the above machine and the start button is continually flashing when I am trying to start a programme because of this the machine wont start please help
  • 2 more comments
  • Anonymous Jan 10, 2009
    i have the same problem start button flashes 3 times but wont start or let me change programme, no matter what button i press it flashes 3 times then does nothing, can ayone help me please?
    my zanussi zwf 1432 w washing machine wont start, it lights up but flashes 3 times then does nothing, tried pressing all buttons but same thing happens flashes 3 times then nothing,......................... please help ty
  • roberttokar Apr 28, 2009
    hi there i have zanusi zwf 1432w and the machine wont spine for eg. if i put washing program wash,rinse,spin it washes rinse but not spin. i have tryed to clean the pies and the drain plus filter but the problem is still there. then i also tried to reverse the drum manualy but nothing happend please can anyone help
  • goozy May 20, 2009
    I have the same problem with the machine, when i press any buttons it beeps and flasses 3 times, does anyone have any idea's. is this a common fault with this machine?
Pcb as the signs were that the pcb was stuck in a programme and unable to change. Anyway, long story short, to fix it:
Take the lid off the washing machine (2 screws at the back) *unplug first
Locate the pcb, unscrew and lift above the washing machine with all wires in tact.
Locate the wires that are coming out of the back of the "program" board, it should be 2 blue wires.
Follow these back to the pcb and unplug
plug in washing machine
Turn on washing machine
Only the on/off light should come on
Whilst on, and being careful, plug back in the wires you unplugged
VOILA, fixed washing machine!!
Right, have to go, got a weeks worth of washing to do!!!!
Posted on Dec 21, 2009
My Zunussi ZWF1432w has all the lights flashing and bleeping, including the orange filter light, I have removed the filter at the front of the machine, cleaned it, put it back, same problem, so I have done the thing with the blue wires, nothing, just the same lights flashing (including the orange light), is there another filter ??
HELP!!!
Posted on Jun 10, 2010
I've answered the 3 flashes & 3 beeps problem here
http://www.howtomendit.com/answers.php?id=266114
Posted on Sep 12, 2009
  • 96 Answers
Normally when the light above the Start button is flashing it means that the machine is in Pause mode. Then you have to hit the button again to get it to start. If it still doesn't work try the Reset button also.
Posted on Mar 07, 2008
Zanussi machine washer. ZWF 1000M The wash button is red. The rinse button, spin button, and power botton is flashing red. This happened several minutes after tuning oN the 30 min cycle.
According to your description it is a failure E9- motor is not working. The temperature rises too high. The motor cut off for heat safeguard (Harness failure, PCB failure).
Dado
Apr 06, 2016 | Zanussi Washing Machines
Error code E20
Turn the dial to off.
Press and hold the start pause and nearest option button to it.
Whilst holding them, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons.
Now turn the dial slowly through each position, stop and position 10 (9 clicks after letting go of the buttons) and note the error code displayed.
Continue turning the dial until you get to off.
Now turn to any programme, then, turn to off again.
Finally, turn to a programme and try the machine.
(It is very important that you turn to Off, a programme and then Off again).
Let me have the error code you retrieved if the appliance still doesn't work.
Oct 14, 2012 | Electrolux Washing Machines
Zanussi zwf 1437 starts cycle then stops midway. door light flashes. have to turn off machine at main switch to reset
This is a door lock fault, the lock is working initially but as the machine operates it fails, the only way to fix it is to replace the door lock assembly
Mar 07, 2012 | Zanussi Washing Machines
The start light is flashing on and off and the programmer wont change to another programme it stays on the normal programme and the dishwasher will not start
Seems to be relatively common. Ma doing one now with that exact problem. If you hold button in for about 10 seconds, it should reset.(switch off then on again to push start.). If same action continues, the electronic module needs to be replaced.
Dec 31, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
Starts ok then skips programmes lights flash then stops without finishin wont complete any programme
starts ok then skips programmes lights flash then stops without finishing wont complete any programme
Jul 02, 2010 | Miele Washing Machines
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
3,280 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
