Question about Brother MFC 9700 All-In-One Laser Printer
Prints have a dark shade
When the prints or copies come out they have this dark shade covering the entire page.  Do you have any idea what is causing this?
  • Turnings Apr 12, 2008
    I have dark shade over entire page too. Just a light what appears to be toner coating. Have replaced toner cartridge as well as new drum. Any ideas out there???
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    ahhh..going over to the dark force, is the brother?
    he..he..ok..did you try a test page, to see if it's that, or maybe the application?
    Also, have you replaced print cartridges lately?
Test page printed properly. Don't know what to look for in the test page or the applications. the cartridge was changed recently
Posted on Feb 24, 2008
Tip
Laser printer has dark cast to entire page, prints ok.
You notice that the copies you print have a dark shadow across the entire page but otherwise seems to print fine.
You have a problem with the toner cartridge.
Toner copier/printers print by transfering toner to a drum using electrostatic electricity and depositing it on the paper. Once on the paper it is set using a heating element or fuser.
Over time the brush which contains the toner in the cartridge and the scraper which scrapes off any excess toner, or toner which is left on the drum, wears and allows extra toner to remain on the drum, which gives the dark shading I mentioned.
To compound the problem these days the cartridges are recycled and obviously at some point the scraper will wear out and you may be the unlucky person who purchased the unit. If that is the case I suggest returning the unit to the store of purchase and exchanging it or getting your money back. Most reputable stores do not have a problem doing this.
New cartridges would run out of toner prior to this problem developing. They have been designed to last slightly longer than the amount of toner which is in them. When recycled and refilled the problems start.
Recycled and refilled cartridges are not always marked as such so there is no way to tell if yours is a recycled unit.
Another problem these days is the drums are being made out of plastic instead of metal. They wear faster and die sooner and cannot be recycled successfully as often. Once they have a scratch they will never print a nice copy again.
If yours is plastic that is probably the problem. No matter which problem you have, worn scraper or plastic worn out toner cartridge, the solution is the same.
You need to purchase and install a new toner cartridge.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 09, 2010 | Office Equipment & Supplies
HP Printing, copying, faxing, scanning black pages
change the ink cartridge & get your printer serviced
Jul 18, 2010 | Office Equipment & Supplies
Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
Printing with double lines and blurry on left side of the page
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP DeskJet 1220c InkJet Printer
Copy Quality
open lid press copy is scanner bulb bright white if not bulb is burning out or has burnt out
Sep 08, 2008 | Lexmark X7170 All-In-One InkJet Printer
PRINTING IS DARK
Dark copies (whole pages) are usually a result of poor charge of the drum. Drum is that green thing (usually, seen blue ones too). You get text and graphics in places, where the drum has been discharged (light discharges drum). So if everything is dark - the drum is discharged fully, or not charged at all. Look for bent, dirty or missing connector plates, springs, paper covering contacts. If you get lines it could also be the fuser (hot thing) - needs replacing. Everything depends on how the copy looks like, I would have to see it. Hope this is helpful somehow ;-)
Aug 28, 2008 | Brother HL 5140 Laser Printer
Printable area
hey did u have page set up .in file menu go through that ....
or u can go to format(icon)at the top in M.S office . go in boarder
& shading set frm there ....
Feb 19, 2008 | HP PSC 750 All-In-One InkJet Printer
Brother MFC 9700 All-In-One Laser Printer Logo
620 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
