Zenith big screen projection tv, wont turn on.
  • 1 more comment
  • jkuro1 Feb 25, 2008
    it worked this morning and then all of the sudden turned itself off and then wont turn back on
  • jkuro1 Feb 27, 2008
    The model number is pv466ovk And its pretty old, i think its 1996
  • jkuro1 Mar 02, 2008
    we put a new fuse in it and plugged it in and the fuse keeps on blowing..... is there any info on that???? Thanks
    Genius:
  • 1,175 Answers
When was the last time it DID turn on?
Are there any little lights on the set that blink when you plug it in?
Posted on Feb 24, 2008
  • 1 more comment
  • Scott Frye
    Scott Frye Feb 25, 2008
    Can you tell me what the model number is and about how old it is?
    Thanks
  • Scott Frye
    Scott Frye Feb 28, 2008
    Unplug it from the AC. Let is sit about 20 minutes. Try to power it up again.
    If that doesnt work, unplug it from the AC . Let it set 20 minutes. carefully take the back off and , where the AC cable comes into the unit, see if there is a fuse nearby. MOst likely 3/4 inch long glass or ceramic with shiny metal ends. If it's glass you can tell if the wire element inside is good or POOFED. If its ceramic , you'll need a continuity tester to see if it's still good or not. If a fuse died that may be your only problem.
    AND check for lots of dust collected inside the set.
    Vacuum out with a plastic tube end attachment
  • Scott Frye
    Scott Frye Mar 03, 2008
    Without seeing the set , I'd say the high-voltage section that runs the proj. tubes has given up the ghost.
    Check with the zenith consumer site on who in your area knows about those. Then ask the tech how much to fix the high-voltage supply.
My zenith big screen tv is out of focus and we cant find any master focus control. How do we fix the focus?
It is unusual for a rear projection to be out of focus since the projectors are fixed. But, it is common for the projectors to be out of alignment, in which case the picture will look like a bad 3D movie of yesteryear.
Go to the setup options / menu, look for the ALIGN option, follow instructions on screen.
Jun 13, 2010 | Zenith R60V26 60" Rear Projection...
There is no picture and no sound but the volume
Unplug the cable box for an hour,replug it back in.Should get the cable box to reboot to updated the softwares.Might work than,tv seem to have picture,somethings on the screen,words mean ur tv still works.
Mar 24, 2010 | Zenith R56W36 56" Rear Projection...
Big arc in picture
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Zenith IQB50M90W 50" Rear Projection...
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
Zenith projection tv convergence proublems
YOU HAVE BAD CONVERGENCE IC'S AND POSSIBLY SOME LOW OHMAGE RESISTORS THAT FEED THE IC'S.
Sep 14, 2009 | Zenith R40W46 40" Rear Projection...
Ripped screen on Zenith 52"Tv
email me at sissyh20@yahoo.com
we have one that dosnt work maybe we can part it out
Apr 29, 2009 | Zenith R57W46 57" Rear Projection...
Tv wont turn on
Unplug it for 20 mins then try again plugged in.
It could be something as simple as an inline fuse but dont try opening the set EVER with it plugged in.
Feb 24, 2008 | Zenith IQB50M90W 50" Rear Projection...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
