GE WSXH208A Front Load Washer Logo
Posted on Feb 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leaking machine machine is leaking from somewhere underneath. the water does not have detergent, bleach or any other additives. what can it be?
Anonymous
Level 3:
Genius:
  • Master 1,019 Answers
  • Posted on Feb 24, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1019
Questions
Helped
388695
Points
2735
possible split hose.
Check the hoses connecting to the Drum and water Pump.
Mike @ Compurepair.
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Maytag 1200 AAW front loading washing machine
What do you mean additive? There are 3 compartments, one for bleach, one for detergent and one for the softener. Which one is it?
Water does not go into the detergent chamber. The water comes out from under the machine on the floor.
Are you sure that is not the "bleach chamber"?
To avoid risk of "bleaching" some parts of clothes with concentrated, bleach, the washer will get the bleach only when water is full & washing has started.
Non-bleaching detergent can just be put in with dry clothes.
2answers
Water is leaking out of the detergent drawer. It
i would say the outlet from the bleach area is blocked clean out drawer unit
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
2answers
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
3helpful
2answers
Dispenser problems
Open dispenser drawer and push down on center plastic tab at back of dispenser to allow you to take dispenser out of machine. Take the plastic pieces off and clean them. (they need to be clean in order to siphon the bleach, softener, etc out. If there is water left in them, the water fill valve is OK. Cleaning should fix your problem. If you are using concentrated additives, try diluting them a bit with warm water when you add them to the dispenser. Remember, only one tablespoon (max) detergent, one teaspoon (max) fabric softener per load.
6helpful
2answers
Detergent goes where?
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 9 years for me.
Maytag Washer, Model # MAH4000AWW (Neptune - front loader) appr. 4 yrs old
Hi john, There is a blue cover that i am suspecting you are missing from the softener/bleach dispenser. It fits over the two tubes in the dispenser and it siphons the water out. It is part number 22002266. Also the machine has a water filled balance ring. It is normal to hear sounds of water when the tub is turned. If you can see water in the spinner its a different story.
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
