Question about Foxconn (945G7MA-8KS2) Motherboard
Foxconn p945 g7ma
Hi, i have a foxconn p45g7ma, sometimes after 5 times it will boot up, no problem with memory becuase i check them ,i think problem with motherboard may be bois corrupted !!!! any idea !!!
  • Anonymous May 22, 2008
    My foxconn runs well during installation, but, after usual drivers installed, and reboot, system fires up 10 minutes. Service SYSTEM in taskmanager indicates that uses 99 % of processor's time.
  • Anonymous May 23, 2008
    every time I turn off my computer it automatic shut it self and reboot again.and other problem is that it crashes every time when I play media files
I think the Advice for me to take out the bettery can be of productive
Posted on May 23, 2008
    Problem Solver:
  • 12 Answers
Turn off. unplug. remove small coin sized battery from board and leave out for about 15min. replace. plug back in. turn back on. this should reset bios to default
Posted on Feb 24, 2008
My foxconn motherboard is power on but there is no signal on the screen and no bios
Hi ' first try to check all wire if it is insert properly but if still not working good the cause is sometimes errors on hard drive to boot your system because of bad sectors ' try to reinstall a new operating system,thanks for using fixya. . . . .
Sep 01, 2012 | Intel Foxconn Motherboard
Foxconn motherboard causes memory to fail on bootup
Hi' try to check one at a time each stick to determine which of those are basted, if one has a problem it will conflict to all sticks ., .. . . .
Aug 03, 2012 | Foxconn A7DA-S 3.0 - Motherboard - ATX -...
Foxconn motberboard will not boot disk
Go into the BIOS settings, Usually press the Delete button during the initial boot, and check the settings for the HD setup. Check your MB manual for BIOS access, and correct setup for your hard drive. Possible it's looking for a RAID array and not finding that.Or some similar issue. Also see that the HD is plugged into the correct socket. With SATA sometime, some sockets are ONLY for RAID drives.
May 04, 2012 | Foxconn A88GMV AM3 AMD 880G HDMI Micro ATX...
Pc doesn't boot up
do you have the right memory to match the cpu
Mar 31, 2010 | Foxconn G31MXP-K Core 2 Quad/ Intel G31/...
Gateway Foxconn C51GU01 (105552) Problem: blue
Possible a memory socket is bad. Make sure you are using the correct type of memory including parity and compatible speeds. It is recommended to use like memory sticks in each slot. Some PCs even require the sticks to be equal memory capacity. User's guide should tell you what the compatible capacities and speeds should be. If you don't have the manual, you can get by looking up your PC model number on Gateway.com.
Bret
1-2-1ComputerServices
Oct 04, 2009 | Gateway GM5084 PC Desktop
Foxconn n15235 mobo will not post nd gives long beep
i think your motherboard is your problem... check your motherboard to other systems.
Apr 15, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Foxconn board
the problem is software, there is nothing wrong with the processor as the machine boots showing that the processor works, have a look at your memory and clean it.
This problem occurs because there is a limited amount of kernel space available for kernel drivers so there is not enough stack space for processing the exception. its an operating system problem, try and boot into safe mode and perform a system restore by pressing F8 on boot up
good luck
Nov 14, 2008 | Foxconn Computers & Internet
Foxconn P9657AB motherboard installation problem
You're Foxconn board uses the Award bios.
The long beeps you are hearing are telling you there is a problem with you're memory.
You're pic does not look like the Foxconn P9657AB-8EKRS2H MB as shown in the user manual. Found on This link.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000297
The pic on Foxconn's site does but not the manual listed.
The motherboard uses four 240-pin slots with 1.8V for DDR2 memory only.
(Question? Did you're ECS MB use DDR2 memory)?
If you have more than 1 DIMM installed remove all but 1.
Move the DIMM into the closest slot next to the CPU.
Boot the PC & check for beeps. If still presant move the DIMM to the next slot & try again. Continue this through all four slots. Than try another DIMM. If the mother board continues to beep as mentioned than call Foxconn. (There is a bios update mentioned below for memory).
The CPU may come into question. (It’s revision). You may have to call Foxconn for this information. (580-272-0035). They do not place this information in their user manual. Most users have to call. The rev of the CPU may conflick with the memory causing you to receive the bios beeps. (I have had to return 2 boards for this reason). I picked an Asus board over Foxconn.
I have come across this with Foxconn motherboards these past two years. Suggest you update you’re bios. Foxconn has a revision dated, 3-28-2008 for memory before you call. After bios update test the memory again for beeps. Still there? Return the board is my suggestion.
It’s a guess that the red led will go away after the memory issue has been addressed. Normally there is a green led on most motherboards. This means standby. The board has power connected. I could not find any reference in the user manual * .pdf, for R450.
Good Luck ninjo61!
Mike
Jun 20, 2008 | Foxconn P9657AA-8KS2H Motherboard
Memory upgrade 512MB > 2GB
Thermal problems becuase of inadequate power . Your power supply to be looked into.
Apr 12, 2008 | Foxconn 760GXK8MC-S Motherboard
Foxconn p945 g7md with 8 channel sound
Open System properties, click hardware tab & than click device manager. Scroll down to Sound, video & game controller. Do you see a yellow ! . This means you need a driver or intergrated controller is bad.
You can download your manual/drivers here:
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000024
Jan 13, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Foxconn (945G7MA-8KS2) Motherboard Logo
198 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
