Retrain the fobs following the procedure in your owner's manual:
Once entering this procedure, programming the first transmitter erases all previous transmitters. You must program all transmitters.
Program one vehicle at a time. One transmitter could be programmed into other vehicles that are also on
program mode in close proximity.
1. Sit in the driver's seat.
2. Remove the ignition key from the ignition lock cylinder.
3. Close all vehicle doors.
4. Press and hold unlock on the door lock switch.
5. While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do
not rotate the ignition lock cylinder.
6. Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain
in the LOCK position for the rest of the procedure.
7. Release the door lock switch. You will hear three chimes. This chime feedback indicates that transmitter
programming is active.
8. Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for 12
seconds. You will hear two chimes. This chime feedback indicates that the transmitter has been
programmed successfully.
9. Repeat step 8 for the rest of the transmitters (for a total of 4 transmitters).
10. Exit this procedure by removing the ignition key from the ignition lock cylinder.
