Question about Sanyo DS31520 31" TV
Can I get more channels?
Hi, my Sanyo TV will not go above channel 47....I have cable and should be able to get up to 70....why? and how do I fix this? *cries*
  • 2 more comments
  • msjj48 Feb 24, 2008
    If I enter a channel number above 47 into my remote it does nothing, just goes to 47.
  • msjj48 Feb 25, 2008
    I have no idea the model number. I'm a college student and was given this set which has been sitting around for nearly 20 years. I'm also having that problem with the vertical output and hope to get that fixed tomorrow. The channel limit isn't 47. I pressed and held "Auto" which is on the TV and it went through all the channels it can get without snowy-ness and it went up to the 60s but then when I type 60 into the remote it still stays at 47. Same thing if I use the channel button on the set. I will look at the set a bit more and try to find a model number or anything I can.
    Model Number: DS13030
  • Anonymous Mar 11, 2008
    My tv has the same problem
  • 20 Answers
If the tv is capable try to directly enter a channel with a remote you should receive the channel if it is snow or garbled pix ,sound you probably have a bad tuner ( band switching ) If you know anything about electronics you can remove the tuner send it Tip Top tuners. Good luck!
Posted on Feb 24, 2008
  • wayne Ezyk
    wayne Ezyk Feb 25, 2008
    Auto-program only works if the tuner is good and the sets bandwidth can go that high older sets were not able to go above that. Your set goes back to 47 because that is probably its limit. What is the model# I will check for you
  • 50 Answers
Go to the menu and navigate to auto-prog(ram)
13'' Sanyo tv skips from 47 to 95.
will probably have to have the remote or a universal will work.....cable tv remotes can be programed to work with most any tv. occasionally you can hold certain button configurations on the tv it's self to bring up the menu then do an auto search
Jul 07, 2009 | Televison & Video
Can not get tv to reach channels from 2 to 70
Sounds like you need a set-top box from the cable company.  You hook that up to your TV, tune the TV to Channel 3 or 4, and use the set-top box to tune in all the channels.
May 20, 2009 | Televison & Video
CHANNEL 47 AND UP ARE BLURRY AND NO VOICE
Try it again in the original room where the TV once was. If the channels from 47 and up are back to normal, its a cable signal issue that the cable company must resolve. Its possible that the installer may have driven a staple thru the coaxial cable or did not correctly attach the fittings.
michtech
Feb 17, 2009 | Televison & Video
Can't go above Channel 20 when input on Video.
I was told by Sanyo and Toshiba that I will have to have a Sanyo remote in order to change the tuner from TV to CATV which he said is causing me to be unable to get above a certain channel and also to change the settings in order to use the Progressive scan cables, so I have emailed a remote finder site and they are trying to find a Sanyo remote for me.
Nov 06, 2008 | Sanyo DVW-7100A DVD Player/VCR
Sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
Feb 23, 2008 | Televison & Video
Sanyo ds325390
Intermittent loss of lower frequency channels ie Ch:36, higher channels ok
Dry joints in UHF tuner, resolder the PCB to casing earth connections inside tuner
Nov 23, 2007 | Sanyo AVM-3259S TV
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
No channels above 47
That works great except I can get the tuner to program any channels above channel47. Is this a limitation of this older model TV yes there is limitation in old tv. is there some setting I can change in order to get more channels using the tv tuner? in INDIA what we do is put a remote control ckt which gives us about 250 channels. of course we replace tuner also called hyper tuner along with remote ckt or replace whole kit which are cheaply available.& serves the purpose. hope this will help
Oct 03, 2007 | Televison & Video
TV problem
Are you using cable to get the picture? If you are, make sure the TV set is in the cable mode,If it is then you most likely have a bad tuner in your set. Good Luck
Mar 21, 2007 | Sanyo AVM-1306 TV
Sanyo DS31520 31" TV Logo
107 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
