Question about Philips bSure XG1 Multimedia Projector
Lamp blinks on bSure XG1
Hi
There is a problem with my old bSure XG1. If I turn it on the projector works for about 2 or 3 minutes without any problems. But then it shuts down and the lamp led is flaching red. I have replaced the lamp but it doesn't fix the problem.
Maybe anyone can halp me.
regards
Chris
    Problem Solver:
  • 8 Answers
Same here with the bSure SV1. Want to find solution as well.
Posted on Jan 15, 2011
Why projector takes time whe it is started
Depends entirely on what you mean by "takes time". These projectors require a few minutes to reach full brightness, and many models even activate an LCD shutter to black out the image until the lamp has reached reasonable brightness.
If you mean it takes several minutes to produce any picture at all, it may just be time to replace the lamp, as it may not be striking (starting the lamp) correctly due to a fault in the lamp starter circuit or the lamp itself. In the absence of a detailed fault description, my best guess is that it's most probably a tired lamp :o)
Apr 07, 2014 | Philips bSure SV1 Multimedia Projector
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
Phillips bSure XG1 LC3141 Projector. Images are dull in colour, and also has yellow tinge all over. Have replaced lamp but this did not fix the problem. Unit ~ 7 years old.
Try opening the unit and cleaning the LCD and lens, and also clean the outer lens- it sounds like this unit may have been stored or used in a smokey environment!
Jun 20, 2011 | Philips bSure XG1 Multimedia Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Dec 03, 2010 | Hitachi 50C10 LCD TV
Sharp PG-M20X digital projector runs 2-5 minutes then shuts off
the Fan has the problem , I had the same of yours. I noticed some particle was inserted in the center of the fan and removed it , worked perfectly. If old one produce little particles.
Good luck.
Dec 03, 2009 | Sharp Notevision PG-M20X Multimedia...
Projector was turned off wrong and now wont turn back on.
if the led flashes once in 2-second intervals and you don't hear a high-pitched whir, the colorwheel needs replacing. if you do, the ballast is bad. if it flashes 2 times, the lamp is past 3000 hours. 4 times, fan error. 5 times, temp too high and it needs to cool.
Nov 07, 2009 | InFocus ScreenPlay 4805 Multimedia...
Lamp light flashing
hi during my investigating i found that the eletrorode surge arrester was causing the problem epcos component 800 083 number i found a device from a projection tv and it worked i also checked epcos web site but could not the accurute device number . they will ask u to use a ruler to measure the device size of the component thanks
Jan 10, 2009 | Philips LCA3123 Projector Lamp for Bsure...
Philips bsure sv1 projector
press menu, then picture, select mirror, then choose the "Aa" which appear to be the right way up for you, then press ok.   Done!!
Oct 04, 2008 | Philips bSure SV1 Multimedia Projector
Philips bsure SV1 , LCD multimedia projector
Pl try M. R. nterprises Mumbai +91 22 23802513/23856204
Oct 29, 2007 | Philips bSure SV1 Multimedia Projector
Philips bSure XG1 Multimedia Projector Logo
95 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
