Question about Packard Bell (181368) Motherboard
My packard bell model number qua-k1
When i turn it on it says no dhcp offers were received
  • 152 Answers
Go to cmos setup and disable "1 boot lan"
Posted on Feb 25, 2008
I plug my ethernet cable to my router/modem. But it doesn't work. I cannot listen to any radio.
Somewhere in the setup or settings for the network on your receiver make sure DHCP is turned on. DHCP (Dynamic Host Control Protocol) allows it to get a IP address and subnet from the router so it functions on the network. Likewise DHCP must be enabled on the router as well otherwise the downstream device (your receiver) won't be able to get an IP address.
Oct 14, 2013 | Yamaha RX-N600 Receiver
Tip
DHCP Server configuration in Linux
Linux is a UNIX based operating system. It is a server operating system. REDHAT Linux is Enterprise version of Linux. Now a day's Most of corporate sectors use red hat Linux as server in their company because it is secure very much.
Full form of DHCP "Dynamic Host Configuration Protocol. DHCP server assigns IP addresses and other network configuration information like subnet mask, broadcast address, etc to computers on a network. The DHCP assignments are the following.
Lease Request: Client broadcasts their request to DHCP server with a source address of 0.0.0.0 and a destination address of 255.255.255.255.
IP lease offer: DHCP server replies with an IP address, subnet mask, network gateway, name of the domain, name servers, duration of the lease and the IP address of the DHCP server.
Lease Selection: Client receives offer and broadcasts to al DHCP servers that will accept given offer so that other DHCP server need not make an offer.
The DHCP server then sends an ack to the client. The client is configured to use TCP/IP. Lease Renewal: When half of the lease time has expired, the client will issue a new request to the DHCP server.
Installation of DHCP server: First of all while install the RedHat Linux enterprise version server be careful about the ports and the services must be turned on. To create DHCP server in Linux first download DHCP RPM package and install with "rpm-ivh" command. Where I have done it there I have create YUM server, so easily I have download and install it by YUM (yum install dhcp version). DHCP package will locate in /usr/share/doc/at Linux file system. I copied the DHCP's files from /usr/share/doc/ to /etc/dhcpd.conf.. Then I started to configure the dhcpd.conf file to route the DHCP server in there local network. I have open the configuration file with "vi" command. Then commented out the lines from "default gateway to option netbios" because system don't read the commented lines. After that I set the range of IP address in dynamic- bootp of their local assumption of system. I have change the "next-server" with the dhcp server name and have also change the fixed address with the dhcp server IP address (end range of dynamic IP). It is very easy job to configure DHCP server. After configure the .conf file of dhcp just turn on the service with "chkconfig" command and restart the dhcp service. After that entire job I reboot the system. And after rebooting of server I turned on the other client system. While startup the client system without static IP address all of those picked up IP from dhcp server and going on successfully. I have prefer the command line mode to do the total job.
The DHCP server configure file is following:
ddns-update-style interim
ignore client-updates
subnet 192.168.1.0 netmask 255.255.255.0 {
# The range of IP addresses the server
# will issue to DHCP enabled PC clients
# booting up on the network
range 192.168.1.201 192.168.1.220;
# Set the amount of time in seconds that
# a client may keep the IP address
default-lease-time 86400;
max-lease-time 86400;
# Set the default gateway to be used by
# the PC clients
option routers 192.168.1.1;
# Don't forward DHCP requests from this
# NIC interface to any other NIC
# interfaces
option ip-forwarding off;
# Set the broadcast address and subnet mask
# to be used by the DHCP clients
option broadcast-address 192.168.1.255;
option subnet-mask 255.255.255.0;
# Set the NTP server to be used by the
# DHCP clients
option ntp-servers 192.168.1.100;
# Set the DNS server to be used by the
# DHCP clients
option domain-name-servers 192.168.1.100;
# If you specify a WINS server for your Windows clients,
# you need to include the following option in the dhcpd.conf file:
option netbios-name-servers 192.168.1.100;
# You can also assign specific IP addresses based on the clients'
# ethernet MAC address as follows (Host's name is "laser-printer":
host laser-printer {
hardware ethernet 08:00:2b:4c:59:23;
fixed-address 192.168.1.222;
# List an unused interface here
subnet 192.168.2.0 netmask 255.255.255.0 {
on Mar 17, 2011 | Computers & Internet
No DHCP or proxt DHCP offered
If your computer is working fine then, disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, and is usually used to load an OS image.
For the most part not a real problem. More of a warning. Some corporate models use PXE to mass image.
Sep 26, 2012 | Microsoft Computers & Internet
No dhcp or proxy dhcp offered
Make sure hard drive is the 1st boot option in BIOS, and an OS on the HD of coarse.
Reply'd to other post on PXE.
Good Luck
When turning on my laptop its saying operating system not found..why is this.
You MBR (master boot record) is bad or damage.You will need to reinstall the OS
Sep 01, 2012 | Packard Bell Computers & Internet
IBM R40 PXE-MOF:exiting boot agent opreating system not found?
This appears to be an indication of a failed hard drive. During the bootup process, your computer looks for bootable (accessible) devices including your hard drive, external drives (if any) and then any other possible mediums like network attached resources. If the hard drive is not available then this would explain your situation.
Aug 25, 2012 | IBM ThinkPad R40 2723 Notebook
My cf29 Panasonic toughbook have no boot file name/ pxe-e53
This error is a network boot error.
The error message indicates that the client received at least one valid DHCP/BOOTP offer, but does not have a boot filename to download.
A fix to this problem is found on this WEB site.
http://www.bootix.com/support/problems_solutions/pxe_e53_no_boot_filename_received.html
May 18, 2012 | Panasonic Toughbook CF-29 Notebook
Some drivers are missing
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Apr 08, 2012 | HEWLETT-PACKARD Hewlett Packard HP...
Packard bell easynote qua-k1 keyboard is not function
You have to get new Keyboard or use external one
Aug 24, 2011 | Computers & Internet
No DHCP or proxyDHCP offers were received. Reboot and select proper boot device or insert boot media in selected boot device and press a key.. What do I do?
Go to BIOS and check the order of BOOT device. Ensure that you have HDD (hard drive) as the first option. you can accordingly set the next alternatives
Aug 20, 2011 | AMD IC Power CN5560 Laptop
Packard Bell (181368) Motherboard Logo
2,318 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
