Surround sound 5.1
When i watch tv on my cable HD reciever and DVDS, it only shows the front left and right speakers displayed. I went through the advance setup many times and tried to set it up the dts and i get no sound. I have it connected as follows, rca cables going from HD Dvr cable box to lcd tv and from tv to receiver a digitial fiber optic cable.
  • 54 Answers
Does your rca cables go to a surrond sound amplifier or directly to the tv. The tv only has two speakers.If the signal is sent to a seperate receiver it must have a lisyen mode then set to 5.1 surround. The digital optic cable should go to receiver first.
Good Luck
big red
Posted on Mar 04, 2008
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
I have this receiver hooked up to a Vizio LED tv and a Vizio Blue Ray using HDMI cables. The surround sound works from the speakers while watching a dvd (HDMI -1 connection) but I have no surround sound...
AV cables don't pass surround sound through, they are pretty much just left and right stereo. You need to turn pro logic on on the reciever to "pretend" to play surround. The better option of course would be to use a digital signal like another HDMI cable or digital optical audio from the cable box, if thats what your using.
Jun 16, 2011 | Yamaha RXV467 Receiver
The back speakers do not work when I watch regular television, only when I watch a movie on the blu-ray or listen to music. How can I fix this?
if you are not watching tv in hd or the show is not recorded in surround then you will not get any sound from them. if this is not the case you can try a simple optical cable run from the tv to the reciever. This cable is about 50 bucks and has awesome quality. Hope this helps.
Feb 26, 2010 | Samsung 1200W 5.1-Ch. XM-Ready Home...
No audio from cable through surround sound
you have to go to the setup for the TV audio and change it to audio out, not speakers.
May 07, 2009 | Philips Televison & Video
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
Can't get Surround Sound with Movie
hiya
do you get full 5.1 when watching a movie from the dvd player...........??
as when u watch tv the reciever must be set to pro logic to enable 5.1 upmix as its only a stereo feed....
Dec 15, 2008 | Technics SA-DX1050 Receiver
Can't get surround sound when watching tv
your RCA on your tv is acting like its in mono..it may be a problem with the jacks.  alternatively..you can buy a splitter and split teh side that sounds stronger (L) or (R) with a male to 2 female spliter out of the tv then back into l/r input on your reciever... It wont give you surround stereo...but it will soudn a whole lot better.
Nov 08, 2008 | Sony STR-DG800 Receiver
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
69 people viewed this question
 Grubhead
Grubhead
