Question about Microsoft Xbox 360 Console
Error 74 I have error 74, and it is not from the cables. I have ordered thermal paste, and I just need to purchase a trox screw driver set. I have watched the youtube video about cleaning off the thermal paste and my GPU. is anyone able to give me more detailed information about how to do the rest of these things? note: I called microsoft and they told me since my i didn't purchase a Warranty I would have to pay 100$ and some other "minor" fee, while waiting 4-6 weeks. I'm not interested in waiting 4-6 weeks and spending 100$ when thermal paste is 69 cents on ebay.
  • leeroi89 Feb 24, 2008
    could you recomend a good place to purchase the best thermal paste?
    Genius:
  • 1,019 Answers
If your sure that the error 74 ( is CPU Or GPU ) Overheating issues, then if your going to have a shot at it yourself. i,d advise investing in the best thermal-paste money can buy. Arctic-silver Or Better.
You should,nt have much problem, Clean off the existing ( patch or paste ) From the CPU and mating surface ( heatsink ) and use a small amount of thermal paste on the CPU when replacing. I,d also suggest checking and cleaning out any exhaust ducts on the blower unit, and de-dust the fan itself. just take your time, replace everything in reversal to dismantling, and you can,t go wrong.
Mike @ Compurepair.
Posted on Feb 24, 2008
How do I repair the E74 error on the xbox 360
E74 - This error is caused by a cold solder joint under the GPU, (H)ANA-chip or in between. Mostly it is one of the outer solder balls on the side facing the (H)ANA chip so a shim increases the chanced of success quite a bit. Can also be a component that is missing or damaged so look for missing parts near the GPU and the (H)ANA chip. Xbox 360 Error Codes Explained and How to Fix Them
Aug 13, 2015 | Microsoft Xbox 360 Console
Tools needed to repair jura capresso
theres many places that i have found that provide the screwdriver to open the jura. before you could only buy them in a single with either a t handle or key chain loop. those are made from aluminum and last for about opening 3 screws and then they break. recently i have seen that single screwdriver is now made from crv steel. normally you will need 3 screwdriver trox oval and philips. they be purchased on ebay or amazon. you can get them in a set also just search for newelectronx 102. that is a screwdriver set that includes the oval phillips and trox. which is basically everything you'll need.
Apr 19, 2014 | Jura Capresso F8 Espresso Machine
How to fix error 74
in order to fix the e74 error you need to take a part your 360 remove the heat sink and apply fresh thermal paste then refasten the heatsink and put the 360 back together do not try a towel trick or any other ilegit way as you will burn out the chip and trashing the entire unit
Sep 23, 2010 | Microsoft Xbox 360 Console
How to remove the cover under the steering colum?
There is two pieces to the lower column plastic...3 screws for the piece closest to the steering wheel and two screws on the lower piece....a long phillips screwdriver (cross-tip) will remove them.
May 12, 2010 | 1993 Dodge Caravan
Cose is 74
Disassemble the console. Reflow the GPU and the (H)ANA chips. Redo the thermal paste on the GPU. Some E74 errors can be stubborn and require more than one reflow.
Dec 23, 2009 | Microsoft Xbox 360 Console
E 74 error message on my xbox 360
thats because that error message means your AV cable has died or the chip inside has cooked, if the error goes away wen you remove the cable its the cable you need to purchase a new one
Oct 26, 2009 | Microsoft Xbox 360 Console
Error E 74 is on display
The Graphics Processing Unit is not working. This requires the xbox 360 to be taken apart right to the motherboard. What has happened is the GPU thermal compound needs to be replaced. Best thing is to send it in for repair.
Sep 05, 2009 | Microsoft Xbox 360 Console
Console
error code 74 is
74: AV cable Error - There is a problem with the AV cable, try using a different AV cable.
hope this solves your problem
Maxicube
Feb 10, 2008 | Microsoft Xbox 360 Console
Error 74
error code 74 is
Maxicube
Samsung Digimax 530 - Zoom Error
Check Customer support at Samsung. Unless you are a wathcmaker you and your screw driver will nothing to help.
Jul 30, 2007 | Samsung Digimax 420 Digital Camera
Microsoft Xbox 360 Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
