PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
BOOTMGR is missing
By jdude8 on Feb 24, 2008
When I try to restart my computer I continue to receive this error. I am working with windows XP pro. What can I do.
Comments:
Feb 24, 2008
- Thanks. However it will not respond to this. once the message appears it says to press control alt delete to restart
Feb 25, 2008
- Yes. Please let me know how to do this with my cdrom drive. Thanks.
Feb 26, 2008
- Thank you I appreciate that. It´s a Compaq Presario 2720US. Thanks.
Same Problem
Mar 28, 2009
-   bootmgr is missing press ctrl+ alt+ del.
I have run a chkdsk /r plus fixboot plus fixmbr.
Is there any other way to sort out this problem? would really appeciate any help. If I go into re install from cd it says i need to format the drive and lose all my data etc which I'd rather not do if I can help it. i am running a generic desktop with new motherboard cpu cables etc. so if there is any hardware issue it's got to be the hard drive.
Thanks in advance -   Guest
Mar 09, 2009
-   i have a gateway laptop, i decided to test drive vista been that my pc says vista redy, at the end of the trial i decided to keep xp, install recovery disk,
everything when fine till it ask me to restart, that's when i got the error message
"BOOTMGR is missing"
Press Ctrl+Alt+Del to restart
i tried Recovery again and again to no avail
plese help this is realy my 4yr old daugther's pc
urs truly nelsun777@hotmail.com
-   nelsun777
Mar 07, 2009
-   Ok my HP xp desk top stopped working , screen says BootMGR missing so I go into bios and says shadowed I click boot menu to select CD to reinstall windows XP I select CD drive boot first
and begine install of new copy of XP . -   muddshove666
Mar 03, 2009
-   BOOTMGR is missing
e-sytem ei3103 how to fix it -   modakas
Mar 01, 2009
-   i have the same problem.
when i boot from xp cd, it loads all the files but at the end, it says windows was unable to detect any hard disk, press f3 to quit.
there is no option for recovery. -   Guest
Best Solution
posted on Feb 24, 2008
Very Helpful)
kykeaton
Rank: Wiz
Rating: 89%, 63 votes
Thanks for the question.
bad MBR is your issue it sounds like to me.
Boot from the Windows XP CD and enter recovery mode.
fixboot
fixmbr
exit
this will recreate that file for you and hopefully straighten you back out.
Comments:
Feb 24, 2008
- As it should.
Put the windows XP cd in the drive before you restart.then follow the instructions I listed previously.
Note: you must have your cd-rom drive set as first boot device in your Cmos
if you need instructions on how to access your Cmos and how to change which drive boots first them let me know.
Feb 25, 2008
- Ok, send me your computer name and model number. For example,.. Compaq Presario 2598US is the model of an old laptop I have.
With that information I can tell you exactly how to get into your BIOS and change the setting so your computer will attempt to boot from your CD-ROM first, rather than your hard-drive. Usually it says when you boot up the machine to "Press F-10 to enter setup" or "Press F1 for startup option". Something along those lines shows up at the bottom of the screen when you turn on the machine.
There are other models though that do NOT display ANY message for this, which is why I ask for your particular model.
Once I have this I will send you the steps for getting this step done.
Feb 26, 2008
- Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen.
Feb 26, 2008
- Once in the Bios, you want to go into the Boot Menu. Here is where you change what drive to boot from first,second,third.
Change the CD-Rom to boot first, then hard disk. Hard Disk usually has a number for example Harddrive 0 ( zero ).
Feb 26, 2008
Navigating through the BIOS
The following table explains how to navigate through the BIOS:
Key on keyboard Description of function
F1 or F10 Enter Setup at the red Compaq logo or blue HP logo
F1 Setup Help
Esc Exit Setup
Up or Down arrow key Selects an item (Moves the cursor up or down)
Left or Right arrow key Selects a different menu screen (Moves the cursor left or right)
+ or - Changes the values of the selected item
Enter Select submenu
F5 Load the Setup default values
F10 Save changes and Exit
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Oct 18, 2009
Somewhat Helpful)
tocuelo
Rank: Apprentice
Rating: 75%, 2 votes
My computer got a virus and i needed to run fdisk. I delete all partitions and create one, then i format it. I used windows 98 to do all that. Now when i tried to install either windows xp pro or windows 98 i got the message: bootmgr is missing, press ctrl + alt + del to restart.
Was this helpful?
Yes
No
Solution #3
posted on Apr 08, 2009
Somewhat Helpful)
squizzie
Rank: Apprentice
The way i fixed this is
1/ incert windows xp disk boot it up get to the consol
2/ type (caps on) bootcfg hit enter
3/ type (caps on) bootcfg /default
then restart computer
windows was all there all programs and was right to go
hope this helps
squizzie
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
I am looking for a TRUE desktop-replacement. I am looking for a quad-core min 4. GB of DDR3... (More)
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
where is location of cmos battery on a toshiba satellite m105-s1021
Answer
got a password on recovery management file on my laptop and i dont know wot it is but i've not... (More)
Answer
where do i get a msi 1012 battery in india
9 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 09, 2009
Having problems with a gateway laptop missing bootmgr .Ihave try to fix it but there is OS
Comment by Guest, posted on Jan 06, 2009
'BOOTMGR is missing'. I've tried restarting and I've tried re-installing windows but I still get the same error mssg. PLEASE HELP!!!
'bootmgr is missing', I've tried loading the windows xp cd but had no success. I keep getting the same error. please help.
Randall
Comment by Guest, posted on Nov 25, 2008
Bootmer is missing press ctrl+alt+del
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
