Question about Pentax Optio 555 Digital Camera
Optio 555 I have Pentax Optio 555 that stopped working when the lens became stuck in the extended position. I turned it on, the lens extended-out, and suddenly the camera was inoperative. Connected to USB to see if PC could override the lack of function but nothing. Can someone provide guidance before I have to break it apart to do internal diagnostics?
  • 4 more comments
  • TYTJAWS Feb 27, 2008
    Now it is stuck open. When I had it plugged in the USB the lens moved but still non operative
    Im sorry am I supposed to replace the battery before holding the button down?
    I took out the battery, held power button for couple of minutes, reinserted battery, got the Optio screen for 2 seconds, then went to blank. No movement in the lens either.
    Any other suggestions?
  • TYTJAWS Feb 28, 2008
    It has a fully charged Pentax OEM battery. I have tried the nudging and it didn't seem to work.
    Master:
  • 555 Answers
According to Pentax, storing the camera lens-down in a warm area for an extended period (a week) can help re-lubricate the retractor drive in cases like this.
This camera seems to have a predisposition to lens retraction problems. Try some gentle nudging, Even a small piece of debris can jam the mechanism, so it might just need a little push or pull.
As for not even turning on anymore- does this camera use a Pentax rechargeable battery, or can it use conventional batteries?
Posted on Feb 28, 2008
  • Matt Jurach
    Matt Jurach Feb 28, 2008
    At this point I wonder if the battery has worn out and no longer supplies enough power to the camera? I don't know if you have access to another Pentax camera where you could test the battery? How old is the battery?
    The USB cable provides only enough power to run the computer inside the camera, so you can transfer pictures back and forth. I don't think it provides enough power to run the lens retraction motor. So if the battery is dying, it would likely result in the symptoms you are experiencing- the camera turns on for just a few seconds before running out of power, and the lens won't move.
    Rechargeable batteries like this one can have a useful life of only 12-18 months, depending on how much it is used.
    Sergeant:
    Champion:
  • 281 Answers
Reinstall it again in the computer
    President:
  • 1,944 Answers
Is the lens totally stuck? Does it even move a little? Did you try to power cycle the camera?
Posted on Feb 27, 2008
  • Damen Wong
    Damen Wong Feb 27, 2008
    Try taking out the batteries. Hold the power button for a minutes or two. Then leave it like this for a while. This should hard reset the camera.
Lens stuck extended, how do I fix this?
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Aug 30, 2011 | Pentax Optio A20 Digital Camera
Pentax Optio S10 - Turning on problem
What kind of shape is your battery in?...old, been charged many times, needs charged, dirty contacts on the battery or inside the camera?
Sep 17, 2009 | Pentax Optio S10 Digital Camera
Spring visible through the lens
Defective Lens Block.
Needs to be replaced.
Aug 15, 2008 | Pentax Optio 555 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Pentax Optio S not functioning
I don't know if it would help but try to update the firmware for the camera.
Jan 01, 2008 | Pentax Optio S Digital Camera
Pentax Optio M20
When the camera is turned on, the lens extends, makes a slight buzzing sound and then retracts and the camera turns off.
Pentax Optio 50 Digital Camera Lens Error
Not really, it sounds like the lens has been bumped while it was extended. Unfortunately, the "buzz" you hear is the gears stripping one another. The only fix is to have the lens assembly replaced, which usually costs upwards of $200. I see this problem at least 3 times a week in my shop.
Oct 27, 2007 | Pentax Optio S50 Digital Camera
Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Sep 23, 2007 | Pentax Optio 555 Digital Camera
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Pentax Optio 555 Digital Camera Logo
152 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
