Question about GE WSXH208A Front Load Washer
GE Washer Rinsing problem
We have GE Washer and Dryer. Recently my GE washer is not RInsing the cloths. Can some one please suggest on this.
Thanks,
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 25, 2008
I have a stackable washer and dryer and laundry detergent is leaking into my dryer (which is on top). How do I fix this?
First check your WASHER. IT MAY NOT BE RINSING AND/OR
SPINNING THE CLOTHES DRY ENOUGH.
I would suspect not rinsing more tho.
Leo Ponder
imufo2@sbcglobal.net
Jul 28, 2010 | Whirlpool Dryers
All our whites are now greys washing with our GE WCVH6260
graying of clothes is usualy caused by / serveral things . too much soap / washer not rinsing properly / and gas dryers. change your dergt. use one with a bleach in it . and use 2nd rinse ( cold water ) make sure washer drains wash water completly . do this by cking the drain pump clean out .. if cloged it will slow the drain cycle and you will be rinsing with the wash water . also use H E dergt. . if dergt is still in clothes when drying this turns nylon yellow and whites gray .. .also seperate colors . and whites .. **** ..
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WM3677HW - no rinse cycle (not rinsing)
Possible door switch not closing or opening.
Jul 30, 2009 | Washing Machines
No rinsing water coming in
There are 2 versions of this washer dryer, a cold fill only one and a hot and cold fill version.
If it is the cold fill version, it could be the water level switch that is malfunctioning, cutting off before the correct level is reached, or a sticking water inlet valve.
If it is the other version, then the same thing applys, plus the coil on the valve that controls the rinse cycle could be open circuit.
You need a meter to test the valve coils for continuity..
Make sure that there is actually cold water to the valve, if it is a hot and cold fill model.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Indesit W 123 Front Load Washer
Washing machine is not rinsing and spinning
Hello ramide,
Huuum At your service!
Try this first as we do when you have an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Jul 29, 2008 | Kenmore Elite HE4 Electric Dryer
My washing machine is leaking water everywhere when rinsing
you are over filling it!!!!!!!!!!!!!!!!!!!! when you use the rinse cycle it just fills the washer up to get all the soap out of the clothes. try just rinsing less clothes then usual. if that is not the problem then on the bottom of your washer is either rusted out or there is a rubber seal that could be over used!
let me know if that helped at all
zac
Apr 20, 2008 | Ariston Technologies AWD121WH
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Ge washer overflowing/not rinsing or wringing well
if you need parts for any apliance go to www.repairclinic.com They will assist you to find the parts you need .
Mar 24, 2006 | GE WBSE3120B Top Load Washer
GE WSXH208A Front Load Washer Logo
81 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
