Question about Vacuums
Bissell 8920 will not suction water.
I think I need the gasket that goes in between the tank and lid, and the one that is on the body of the cleaner where the tank meets it, but I cant find the parts
Go to a Bissell service center and ask for it or maybe call the customer service support line that is listed on the vacuum.
http://www.bissell.com/Service_Centers.aspx
Posted on Feb 26, 2008
My Bissell Proheat 8920 carpet cleaner does not suction water
its pluged check the hose that goes to the tank ill bet it hasnt ben rinsed the dirt sets in the hose and dries and it gets like concreet but this will solve the proublam
May 21, 2012 | Vacuums
My shampoor will not pick up the dirty water?
If your ProHeat 2X machine is not suctioning properly, first check the motor duct gasket. To check this, first remove the tank and place your hand over the rubber square opening. If there is no suction there, please take your machine to a BISSELL Authorized Service Center for inspection. If your machine does have suction at the duct, continue to check the following:
- Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
- Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
- Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
- Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
- The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
- Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
- If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced.
- Check the Tank Lid and Tank for damage.
If you continue to experience low suction, please take your machine to a BISSELL Authorized Service Center. The warranty on your machine is one year. To locate your nearest BISSELL Authorized Service Center, click here.
To contact Consumer Services by phone, please call us at 1-800-237-7691, Monday - Friday 8 a.m. to 10 p.m., or Saturday 9 a.m. to 8 p.m., ET. A representative will assist you.
Apr 19, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell does not have any suction power. It sprays the formula but will not vacuum it up.
First check the motor duct gasket. The motor duct gasket is visible once the tank is removed. It is located underneath the handle on the top of the base of the machine. It has a black rubber coating around it. If there is no suction there please let us know. If your machine does have suction at the duct, continue to check the following:
- If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced. This tank may need to be emptied.
Nov 23, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have bissell cleaner 8920 it will not release the cleaning fluid and water
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If your machine continues to not spray, contact BISSELL Consumer Servies at...
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Aug 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
MY BISSELL SEEMS TO HAVE THE SAME PROBLEM AS EVERYONE ELSE - NONE WHICH TO MY KNOWLEDGE HAVE BEEN RESOLVED. MY MACHINE WILL DESPENSE BUT NOT SUCTION - WHAT GIVES WITH BISSELL -IT THIS AN ONGOING PROBLEM
Please check the following:
If you continue to experience low suction contact BISSELL Consumer Services at ...
1-800-237-7691
Sat: 9am to 8pm ET
Aug 16, 2010 | Bissell 9200 Upright Vacuum
My bissell pro heat 2x does not **** up the water from either the upholstery cleaner or carpet cleaner. Any thoughts as to why? The water and heat functions work it just does not pick up
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell will not suction water from the carpet
If you continue to experience low suction, please contact BISSELL Consumer Services at...
1-800-237-7691
Sat: 9am to 8pm ET
Apr 09, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
No suction of liquid off floor.
This unit has to have some type of clogg in the hose or unde neath the unit. Check to make sure that you have suction in the hose first.
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Bissell ProHeat 1699
There should be a black oblong gasket that sits between the edge of the noozle and the lip of the tank, If it is missing, then you will have to suction there. Also there should be a plastic red filter, mounted on the tank lid, covering the suction port, it it is clogged, then no suction.
Aug 20, 2008 | Bissell 1699 ProHeat Clear View Upright...
No Suction
Between the top edge of the clear noozle and the lip of the tank that sits on it, there should be a black oblong gasket, if missing, you will have no suction there. The other is the filter on the tank lid, is it clean?
Jul 08, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Vacuums Logo
188 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
