Question about Dishwashers
Dishwasher won't drain
I took out the drain unit in the bottom of the dishwasher to clean it.
1. I took off 2 hex bolts(screws) and an oval white plastic cage(about 1' tall) came off.
2. Next, two white plastic parts came out. One has an oval top about 1" deep. The other white plastic part is also oval and has 2 screens going down, perpendicular to the top.
3. I gently pried the 2 push washer-like grips off the front of the large bottom screen in order to clean under it.
Sooooo,
1. I wasn't paying attention when I took the 2 white plastic parts out and need to know how to put them back in. Yes, next time I WILL pay attention! I can't find a diagram on the web and GE customer service is not open.
2. Can I reuse the little push washer-like grips to secure the bottom screen? If not, can I take them to Home Depot and get some new ones? Or a local plumbing place?
Hope that you can help me.
Sherry
  • butterfly3ej Feb 24, 2008
    I also took the bottom of my dishwasher apart and apparently did not get it back together properly. The dishwasher is now making an odd sound. Any help with this would be wonderful.
  • 21 Answers
Good Day Sherry, GE has used several different designs in the past couple of years. It would be helpful it you could list the model for your unit. When you open the door and glance on the left side.. what you're looking for would be a gray label about 1 inch wide and 4 inches long. It will say Model and be something like PDW8200... or GSD5900 that way, we would be able to identify, which particular drain system is used for your particular model. Can we start with that..?
Posted on Feb 25, 2008
Samsung DMT400 continuous drain and fill
We had the same problem and thanks to a woman who posted a solution in January, we were able to fix it at home at no cost. The solution is to pull out the unit, remove the panel on the left side of unit, tap on the clear box that is at the bottom of the unit ~ it has a float in there that got stuck, therefore signalling the dishwasher that there is a low water level. After tapping on that, the float came back up to the top of that clear box (we started the dishwasher before this procedure in order for the water to flow into the dishwasher). That's all it took. I then put a cup of white vinegar into the dishwasher to clean some of the gunk out of the unit. Our unit is only 1-1/2 years old. Hope this helps.
Apr 22, 2014 | Samsung DMT400RHS Builtin Dishwasher
Whirpool DU1055xts water does not drain after wash
There is a fourth screw under the spray arm. Here are some instructions I put together to clean out the pump. But I do not think this will help the drain. The drain hose or drain pump could be restricted.
The best way to find the restriction is work backwards. Start at the sink where the dishwasher drain hose connects, take that connection apart and try to drain into a bucket. If it does not drain the work your way back to the dishwasher checking at every connection point.
This link will be for the pump cleaning.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
May 08, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Dishwasher won't drain, filled with dirty water
My husband and son actually fixed it and proceeded to do the Happy Handyman dance all over the kitchen. They took off the kickplate on the front, and cleaned out the hose, then took off the sprayer in the center of the unit and cleaned it out too.....lettuce, a plastic spoon, dog hair and a set of vampire teeth later, and my dishwasher is working like new. Also, I ran a cup of white vinegar through just to get rid of the stink and it worked great!
Dec 13, 2009 | Whirlpool Dishwashers
Dishwasher will not drain all the water out
If this is a GE or Hotpoint dishwasher the solution is fairly easy, but a pain. GE (Hotpoint is the same company) has been using a small plastic ball that prevents backflow of the water. A lot of times that ball migrates and doesn't allow the dishwasher to drain. To get to this, you need to remove the two 1/4 inch hex head screws in the food trap basket, the 1/4 inch hex head screw from the spray arm, and use a small screwdriver to pry a clip at the back of the spray arm up to remove the spray arm assembly. Siphon as much water from the dishwasher as possible because you'll be opening up the plumbing below. Turn off your electricity to the dishwasher and pull it out of the cavity. Directly behind the motor is a large manilla-colored "tank" with a large hoseclamp holding a white union with two smaller hoses coming off it. Loosen and remove the white union from the large tank and the ball should fall out. Replace the white union, tightening the hose clamp and drop the ball back into the tube on the left side of the food trap basket. Put it back together and test run.
Sep 10, 2009 | Dishwashers
My bottom dishwasher drawer won't drain fisher and paykel brand
We took apart the base - cleaned out the rotating arm, pulled up the filter unit and washed it completely, and put it all back together. It could have been a combination of a kinked hose and a dirty filter, who knows, but its working beautifully now.
Aug 04, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Water will not drain. Motor is working. Drain does not appear to be clogged.
GE has equipped many of their dishwashers with a crappy anti-syphon ball. The problem with this is that they often relocate and clog the drain. To fix it, syphon all the water out of the basin of the diswasher and remove the kick plate. Open the dishwasher and remove the 1/4" hex head screw behind the food screen and remove the spray arm by prying the plastic clip on the back side (be careful not to break it). Then remove the two 1/4" hex head screws in the plastic basket and remove it. Remove the two screws that hold the dishwasher to the countertop and slide the dishwasher out. There is a large manilla colored hose with a huge hose clamp on it. Have plenty of rags on hand because this part gets messy. Remove the hose clamp and pull this area open. A small white plastic ball should roll out. Replace the hose clamp and slide the dishwasher back into place (clean up all the water that escaped first, and make sure you have turned off the power to the dishwasher before beginning). Drop the ball into the small tube on the left side under where the plastic basket goes. Installation is reverse of removal.
Aug 03, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
I have an error code of 5UD or SUD and the water is not draining
If you are getting an F2 error message or a SUD error message, and are observing some water in the tub that is not draining at end of cycle, and your washi cycle is taking a lot longer that normal to complete,then here is what to do.
This solution is easy, and will take no more that 15 minutes, from start to finish, and most of that time is in the --prep-- (getting tools, towels, etc.). This WILL save you a expensive service call.
There are 3 small 9/32 hex head screws that hold the front panel on. The front panel I'm speaking of is --below-- the washer window.
These screws can be found::
a. if you have the optional washer storage drawer unit,, they can be found by opening the drawer, and observing the 3 screws (left, middle, and right side, that hold the front panel on.
or
b. if you DONT have the optional drawer assembly, then they are found on the front, bottom, of the washer, again holding the front panel on the washer.
1. unscrew the 3 hex head screws (9/32 socket or nut driver size)
2. lower/remove the front panel, and set it asisde on some towels, so as not to scratch the front panel.
3. get something now to soak up at least a gallon of water that WILL empty onto the floor.
4. observe large WHITE drain cap, at front center of washer.
5. unscew white drain cap --WARNING-- lots of water WILL drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
6. clean out the front and bottom of the filter trap. I'm sure lint, and gosh knows what else have cloged some of the holes
7. wipe out the inside of the housing for the filter trap (observe lots of -gunk- there too).
8 put back in filter trap, tighten white cap, and put front panel on washer with same 9/32 screws you took off earlier.
Now I ran a test --express wash-- cycle, just to be sure all was OK,, and it was.
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Miele blinking intake drain light
If you checked the intake water filter and drain filter and still have this problem -- Try this...
1 - You need to take the diswasher out.
2 - Turn it on its side so you can access the bottom panel.
3 - Unscrew the bottom panel
4 - Take off the electric circulation motor (big electric motor with a bunch of hoses going into it (it is the biggest motor -- not the small motor at the front of the machine (this thing actually screws in place from the back of the machine). To take the motor off - just unscrew the bolt from the back of the machine and wiggle the thing out from the seal.
5 - Unscrew the 4 screws (need a one of those special star screw drivers) that hold the motor to the pump mechanism
6 - Turn the wheel to unseize the motor -(it takes very little pressure to do this) and reinstall it -- it will very likely work again (if it does not - you need to replace this motor)
There is apprently an easier way to do this from inside the machine - but meile technicians have a special tool to go in and turn the motor blade to unseize this. It takes very little pressure and I think it would be a crime to pay someone else to do this -- it is so simple....
So, in summary, first check to make sure there are no blockages in the filters - then try this...
good luck!
Aug 08, 2008 | Miele Incognito G818SCVi Built-in...
Indesit dishwasher DV62
You have a blockage in your drain pump. Remove all filters and scoop out as much water as you can from the unit. Check in the bottom for any objects stuck there. Some models have a cover on the bottom inside the unit, which once removed, will expose the drain pump impeller. If yours does, remove the cover(usually 1 screw only) and free the drain pump impeller. NB: DO NOT REMOVE THE SCREWS WHICH HOLD THE BASE TUB IN PLACE! These are the screws on the edge of the white plastic "bowl" inside the unit. The drain pump cover will be INSIDE this bowl and will be quite small, no more than 5cm dia.... If this does not work, you will have to remove the drain pump from the bottom or front of the unit to get the blockage out. Oshie
Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishes not getting clean
Yes I had the same problem and just fixed it for $7.00. Did not even had to take anything apart. This is what you will have to do. If this dosen't work then try what these experts are suggesting. Please follow these steps for optimal results. #1 Break off a plastic Tea spoon. #2 Put it in place of a LATCH to by pass so you can watch the operation of the dishwasher.(put down some towels for water spill) #3 start the dishwasher on normal cycle. #4 Pour in Gallon of White Vinegar($2.00) while the Dishwasher is being filled. #5 Let it run through its cycle. After the cycle is complete water will drain out and then actual cleaning cycle will start. Then #6 while the dishwasher is being filled again pour in 48 OZ or bigger bottle of CLR (Calciam Lime Rust) it is available at Meijer, walmart, Rite Aid, Home Depot Ace Menard's etc. for $5.00. sit by the dishwasher and listen for it. if you hear water draining pull and push the water plunger so it won't drain so you don't loose your CLR down the drain. since you have the spoon in the LATCH your dishwasher will always be on so BE CAREFUL when you stick your hand in it. And after the cycle is complete enjoy your NEW DISHWASHER.
Thanks
Kashif.A
Nov 06, 2006 | Jenn-Air JDB6510 Built-in Dishwasher
Dishwashers Logo
251 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
