Dell INSPIRON 1300
I have been told by Dell that the mother board needs to be replaced on my Dell INSPIRON 1300 although I have heard that all I need is to have a small soldering job to solve my problem of my laptop not charging.
could this be the case and if so is it possible to DIY this job?
  • 35 Answers
Assuming it's not under warranty or you wouldn't even consider this so here goes..
If it's not charging because of the connector on the motherboard has in some way become defective
which happens quite often. ( I have a Compaq with that very issue on my desk ) You can order
a NEW connector from various places on the internet at a cost of approx. $20-$30. There are also
listings for companies that specialize in that area that I am sure would be less expensive than getting
a whole new board from Dell ( Google search: Dell restoration & repair ) , at a cost between $40 + shipping
and $125 + shipping. Do the research to find reputable sources. ( check reviews ).
Hope this helps..
Oh you CAN do this yourself if your comfortable with board level electronics. Keep in mind you would be
dealing with micro technology ( very small solder points ). This is why I let you know the option of having
someone else do the repair. With that you'd get a warranty on the repair and have it done by someone
experienced in the matter at hand.
Posted on Feb 24, 2008
  • 682 Answers
Dear friend: soldering and desoldering in multilayer board is not so easy if you have good experience and suitble soldering iron go ahead. if ot better to pass it to qualified person.
My dell inspiron 1300 laptop does not power on. There is no indication of power at all.
is it on battery or straight to the mains?
Try to run on battery. If it fails, remove the battery and connect the notebook to main power. See if it changes anything. If you have extra chargers, try them as well. This is to illiminate the causes of this problem.
If all these fail. Then there might be a problem with the components or worse the motherboard. Try One of the components may be shorting. Remove any connected peripherals and plug the battery or the mains again and see if it changes anything. If it doesn't, most likely a motherboard fault. You either have to replace the mother board or buy a new notebook.
hope this helps.
May 05, 2011 | Dell Inspiron 1300 Notebook
Dell Inspiron 1520 extremely dim screen and double beep at start up
You have a inverter circuit that is malfunctioning and needs replacement if it is on the mother board the mother board may need replacement . There also may be a failing video card.
Apr 22, 2010 | Dell Inspiron 1520 Motherboard
No power leds. My Ac adapter is new with the right voltage coming out. I have to keep on unplugging the power cord then the green light comes on my Dell Inspiron 1300....I took the Laptop apart and solder...
You will probably find, that the power Jack on the Mother Board has fractured the solder joint, this is a common problem. You may have to get it to a shop.
Mar 08, 2010 | Dell Inspiron 1300 Notebook
Bios when you start up
You need to remove the battery from the mother board. There is a small battery, like a watch battery, on the mother board, but it is not an easy task getting to it..
You'll probably need to download instructions for taking the laptop apart.
When you find the battery, remove it for an hour or so. Put it back in and reassemble. The password will be gone.
Apr 07, 2009 | Dell Inspiron 9400 Notebook
Dell inspiron 1300 Video card upgrade
Sorry you cannot upgrade the graphics on your laptop according to the articles i looked up.
You should call DELL. I think the display card is part of the mother board on your computer. In this case, you cannot change it. In some models you can add some memory to the display card, but this may not make the card faster. Higher amounts of memory allows for more resolution and colours.
Dec 22, 2008 | Dell Inspiron 1300 Notebook
Problem with the mother board.
A replacement motherboard for a Dell Inspiron 516 may be found at:
Pls confirm part number, availability, other related details and shipping cost.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 27, 2008 | Dell (S423) for Dimension 8100 (3F546)...
Will not power up
This could be a bad memory chip. Try taking out the memory, putting one or the other in and starting, then changing them out and starting. If it's not a battery or memory, then the problem will most likely be with the motherboard. You will need to take it in for a professional diagnostic in order to find out whether it's a replaceable component on the board or if you will need a new board.
Jul 12, 2008 | Dell Inspiron 1300 Notebook
Dell Inspiron video card
Jerry G.
May 12, 2008 | Dell Inspiron 1300 Notebook
Computers & Internet Logo
64 people viewed this question
Alun Cox
David Payne
David Payne
