Question about LG WM-2277HW Front Load Washer
LG Tromm hot water only
No matter what setting I use and no matter what cycle I set it on the washer uses only hot water! I checked the obvious - if hoses were connected hot water hose to hot water valve and they are indeed connected correctly after the last filter cleaning. Could it be clogged cold water hose? I will be grateful for any suggestions.
Ava
  • AvaSJ Feb 27, 2008
    We doublechecked the hoses connections and... they WERE switched! We reconnected them correctly and all works great again!
    Thank you for your suggestions!
  • 156 Answers
I have found the water inlet valve bad and also the main control board can cause it
Posted on Feb 25, 2008
What does error code OE mean?
For LG washers, the OE error indicates a problem draining the wash tub. This could be caused by a problem with the drain hose, a clogged filter on the drain pump, or a problem with the pump itself.
First make sure that the drain hose isn't kinked or too high for the pump to force the water up. (Most washers can pump the water 4-6'.) Next grab a bucket and open the washer to reach the pump. (Usually you either need to remove a plate below the door or an access hatch on the back.) Find the pump and open the filter that is on the front. Remove any foreign objects from the filter. (Use the bucket to catch any water that spills.) Look into the pump itself and check for any obvious objects.
Try a new rinse cycle and see if the error persists. If it does, then the pump or the pump motor has an problem. If you add a comment with the model number of your washer, I may be able to find the correct part numbers for the replacements. If your washer is under warranty, contact LG.
I hope this helps.
Dec 27, 2014 | LG Tromm Front Load Washer And Dryer Set
Water remaining in detergent dispenser on LG Tromm front load washer?
The water usually drains from the drawers just by gravity. Have you checked that your machine is level?
Nov 19, 2014 | LG Tromm Front Load Washer And Dryer Set
UE Error Code on LG Tromm Washer
From back or underneath, check that all three shock absorbers are attached. Take top off and check if both springs are in place and un broken
Mar 22, 2017 | LG Tromm Front Load Washer And Dryer Set
LG tromm mold smell.
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Please post back for further assistance. Hope this helps...
Daniel
Sep 01, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm Washer
Wash empry with detergent and double bleach with extra hot water. When cycle is complete open the door to the washer and let airdry. When you close the door with it wet it becomes a breeding ground for bacteria. You may also not be using the correct detergent or the correct amount of detergent.
Jan 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Smell on towels
It's good that you are using HE detergent but you're probably using way too much. To test this run the washer empty (no soap) and if you see bubbles inside that's left over soap that's still in the unit. If so, keep running it empty until the bubbles are gone then start using only about 1 tablespoon of soap per load. The washer uses about 1/10 of the water so you need to use 1/10 of the soap. Use the same amount of softner. The excess soap and softner build up in the unit and cause the smell.
Jan 18, 2008 | LG WM-2277HW Front Load Washer
LG Tromm Washer
Embarrassing as it was, the hot/cold water hoses were switched - although it was installed by HomeDepot that way. It just didn't seem consistent enough for it to be such an easy solution...but it did the trick!
Dec 20, 2007 | LG WM2688HWM TROMM SteamWasher
LG WM-2277HW Front Load Washer Logo
177 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
