Question about Nintendo 64 Console
Diagonal lines Hello, I bought a used Nintendo 64 recently. It works , but my screen has diagonal lines running through it like some kind of interference. Is there anything I can do to get an interference free picture? Thank You Nola Powers nolarose26@comcast,net
  • nolarose Feb 26, 2008
    nesfixxa400, No I am not using a rf switch. Thanks Nola Powers
  • anonymous anonymous May 11, 2010
    are you using an rf switch?
    President:
  • 894 Answers
Well it sounds like that thers and internal issue with the console for this to happen like a harware issue then.
Posted on Jul 21, 2011
Nitendo
Posted on Jul 27, 2008
Sucker
Posted on Feb 24, 2008
Why is there no sound when I use nintendo on my Sanyo tv?
Nintendo64 Sound ' Nintendo Tech Forums
techforums.nintendo.com > ... > Discussions
Jan 30, 2013 - 6 posts - ‎2 authors
I have recently started playing my SNES and 64. I am playing ... However, when trying the 64 I get picture but no sound. I am using an ... I hooked the 64 up to a Sanyo tvusing the adapter and it worked just fine. My Samsung ... Connecting NES & SNES To A Modern Flat Screen TV ...
Jul 10, 2014
Nintendo 64 on Samsung Smart TV -... ' Nintendo ...
Dec 19, 2012
Wii U not Outputting to TV ' Nintendo Tech Forums
Nov 17, 2012
How to connect Wii to Sanyo Tv? ' Nintendo Tech Forums
May 29, 2012
More results from techforums.nintendo.com
Sanyo HDMI issue - Forums - CNET
Jan 13, 2016 | Sanyo Televison & Video
My Paper Mario 64 game isn't working. Other video games work in the system.
The contacts on the game pak are corroded.. look at the end of it to see if you see a bunch of shiney contacts on the board.. if they are dirty looking you need to clean with a pencil eraser.. run on them and they will shine right up.
Jan 10, 2015 | Nintendo Paper Mario 64 N64
I bought a new AV cable for my nintendo 64 off ebay and when i plugged it in the brightness of my games were really bright
Well it could be because HDTV was not made the time N64 cameout so you would have to use a blue plug for it to work instead of the traditional av cables.
Jan 19, 2012 | Nintendo 64 Console
Hi I'm having a problem with my Nintendo 64, it won't play the game. I just recently bought Super Mario 64 at a yard sale, and when i got home it doesn't work. I unplug and plug everything,...
Well It might be the gamepack but the only way to test it out is to try it one a different N64 console to see if you have any luck if it works somewheres else than your N64 console has an internal problem of it 0 luck on something else than Its a fake gamepack because the old consoles will reject fake game packs then.
Aug 13, 2011 | Nintendo 64 Console
How do transfer packs work? Will it work on a nintendo DS?
A Game Pack is the game cartridge you insert to play a game. GameBoy Advance Games are not compatable with the Transfer Pak. The Transfer pack and Pokemon Stadium 2 only support the following: Pokemon Red, Blue, Yellow, Gold, Silver and Crystal versions. No Ruby will not work with the transfer pak as you will not be able to insert it, and the software would not pick it up.
May 17, 2009 | Nintendo 64 Console
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My nintendo light comes on but the screen stays blank
Clean the control deck and the cartridges. Check the input cable to the TV.
Hope this helped :)
Oct 26, 2008 | Nintendo 64 Console
Nintendo 64 problem
Same problem with mine, i figured out that if certain parts inside the n64 are damaged or worn, it will affect the display of the game
Aug 03, 2008 | Nintendo 64 Console
Diagonal lines on my screen(samsung 55" projection HDTV hcn553w)
Here's the link to the user manual; http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=32370&CDCttType=UM&ModelType=C&ModelName=HCN553W&VPath=UM/200310/20031002105141187_P55A_00054A_0410.pdf Check page 28 and 29 for convergence instructions. Give it a try to see if it makes any difference. Check page 27 for the "perfect focus" feature and see if that helps. Could you take a photo of the "diagonal lines" on the set and post it - might help? If you open a menu on the screen, does it also have the lines across, or is it clear as normal. Check page 64 for how to run the demo, and try that. Have you recently unplugged the set from the mains power supply, left it for at least 15 minutes (preferably two hours) then turned it back on? if not, try it and see if you get any change. Check page 38 for the usual video settings - play around with them and see if any significant change? Check page 39 and set the "automatic picture setting" to standard, if it isn't already, and something else if it is - see if you get a change. Check page 40 for the colour tone adjustment - probably won't change anything, but worth a play in case. Check the bottom of page 46 about channel fine tuning - reset at least a couple of channels to 00, see if that makes a difference (long shot). Does the screen itself need cleaning? recommended is just a clean dry cloth - basically have a good close look at the screen when it is both on and off, to see if there are any marks that might be causing the problem - in particular has it possibly been cleaned with a solvent or too aggressively cleaned in a diagonal direction? shine a light on it at a few angles to check, and look from a few different angles too. Check by moving or turning them on and off if any other electric or electronic items near your tv may be causing the effect - speakers perhaps. Move speakers to check. A way to check other items is to totally cut off the electric supply to the whole house for a couple of minutes, except one circuit into which you can plug the TV and a picture source. See if you get a perfect picture - if so, start switching circuits back on 1 by one until it changes. Hope this helps - I think a photo would help a lot :)
Jul 16, 2007 | Samsung HCN553W 55" Rear Projection...
Nintendo 64 Console Logo
171 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
