Question about Mitac Mio C220 GPS Receiver
Cc220 need help
When i trun it on it say error
insert sd card
  • 4,369 Answers
Hold down on/off button to power down. Then repeat to reboot. may take a few trys.
http://service.mio-tech.com/M0100/MainFrame.aspx
Posted on Mar 01, 2009
SD Card states error card when inserting and turning it on.
you need to go into the settings on the camera and ask it to format
May 30, 2013 | Vivitar Cameras
After inserting memory card the error 'this card cannot be used' has occured
The L105 works with SD cards. Make sure you're not using an SDHC card. You need to use SD cards, 2GB and smaller.
Oct 29, 2012 | Nikon Coolpix L105 12.1 Mp Digital Camera...
Erase memory card
is the card removeable....if so..can you insert it into the memory slot on your laptop and find it in your "my computer"... and erase it there...I do this with my SD cards for my camera...
phillip
Jul 04, 2012 | Jazz Cameras
I am getting error message that sd card is blank and/or when i want to use my camera error message comes as insert your sd card..i try to format the sd card by following format sd card section but nothing...
Try formatting your SD card by plugging in Laptop's or using a memory card reader. Don't use the cell, after formatting insert in cell and re-format. it will work.
Nov 10, 2010 | Sony Ericsson XPERIA X10 Cell Phone
The problem could be your SD card. Try your SD card on a friends phone. If the same problem occurs, get your SD card repaired. Most SD card companies provide you with unlimited warranty so there should not be a problem.
Aug 01, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola k1 cannot format unformatted memory card
sometimes there are sd card errors make you format failed. you may get messages like
"Unsupported media card inserted, format now?" error in your smart phone,
"Media is not formatted would you like to format now?" error,
you need to fix sd memory card errors first and them format you sd card.
Jun 04, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Can't detect SD card
Try removeing your sd card. start your tt and after it has booted then insert the sd card.
Hope this helps
Nov 21, 2008 | Tomtom ONE GPS Receiver
My pentax k100d has a memory card error
Trun the camera off and remove the batteries. Leave it for at least a minute before inserting the batteries. Put the car in and turn the camera on.
The firmware in these cameras can get confused. Removing the batteries for a minuite or two will allow the camera circuits to discharge and so it will reset from start when powered-up again.
If this does not work then the camera may need to be sent away for repair. This need not be expensive it could be as simple as re-programming the camera. (Their program memory is writeable and so it can be accidentally altered under certian circunstsances. It may be possible to do this yourself using the downloadable firmware upgrade, but I would let someone else try thet first!)
However, it is just possible that the new card is also faulty!
Check the cards in your PC by obtaining a SD card reader to allow you to plug it directly into your PC.
For reference I would always recommend inserting and removing memory cards with the camera turned off. I would also use the SD card reader to load the images into the PC. Unplugging devices form the USB port can be harmful to some devices. Check the bottom right of your PC screen for an 'safe unplug' icon when things are plugged in.
Oct 01, 2008 | Pentax K100D Digital Camera
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
Mitac Mio C220 GPS Receiver Logo
60 people viewed this question
Top Mitac GPS Experts
Greg Cann
Greg Cann
TO Lady
Are you a Mitac GPS Expert? Answer questions, earn points and help others
