Question about Whirlpool AWM5125/1 Front Load Washer
Wont spin and drain!!
Hi there, its actually a whirlpool AWM1203 washind machine i have. the problem is i dont know how to clean the filter! the filter door on the front will open and when i screw out the center piece it wont come out fully. should it come out fully for me to clean or am i barking up the wrong tree?? thanks for any help you can give me.
Hi there, thanks to everyone who responded to my problem!
I solved it with a collection of ideas posted, first i was able to actually get the filter out fully, it was being held in place by a hair clip, a little gentle persuasion solved that! secondly the drain hose was partially clogged and the suggestion to snake it out worked a treat. once again thanks to everyone who helped the machine is back in full action!!!
Posted on Feb 25, 2008
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
  • prem mathew Feb 25, 2008
    Click on your model number (below FIXYA )on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
Wont drain
Hi.
If the machine does not drain the parts that can be responsible are the drain system and pressure switch. Motor and control board must also be tested if the first two are Ok. If machine is a top loader testing will start from lid switch. a first action will consist in checking the drain hose at the back and checking the drain filter accessible from lower front side of your Whirlpool.
Here a page about drain and spin problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 14, 2011 | Whirlpool WFW9150W Front Load Washer
Ghw9100lw1 washer is not draining as well as it should. I believe the pump may have some debrees in front of it or something. The drain hose and line are open and draining freely. The machine is making...
Hi browny376,
You may need to clean the drain filter on your machine, find instructions on how to do it, by reading this following tip:
ACCESSING AND CLEANING THE DRAIN FILTER
Kind Regards :-)
JEDEMEYER1
* If you found this solution helpful, please rate it.
Jul 12, 2011 | Whirlpool Washing Machines
Hi me and my partner have tried on numerous occassions to open the filter to our whirlpool AWM1203 to clean it and it never opens fully and doesnt come out is there any solutions to this thanks katie
Hello, Thank You for using FixYa. I will be helping you today. Sounds like something is stuck in there like a sock or something. You might have to pull the hose off from the back side of the filter housing to get out what ever is stuck.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Whirlpool AWM5125/1 Front Load Washer
I have a whirlpool front loading washer model number ghw933pw4... I have a code of f-6 that flashes and wont drain.... Now it wont get out of wash cycle , and flashes number where its at in cycle... ex- 50
Hi from retired Englishman in SW France @18:00 Sun afternoon/evening.
If, as you say, it 'wont drain' that is sufficient for the machine not to be able to continue operating. You will need to find and check and, if necessary, clean the drain motor lint tray/filter especially if you have had the machine for some time and the filter has not been cleaned. I try to remember, or am reminded by my wife, to check ours about every 3 months
Although I do not know your particular model the filter is normally to be found behind the lower front panel which is held in place by some plastic screws. These are (normally again!) removed by turning through 90 degrees anticlockwise.
REMOVE POWER FROM THE MACHINE AND HAVE A WATER RECEPTACLE AND/OR RAGS TO SOAK UP ANY WATER!
The cover/large knob for the filter should then be visible and turned anticlockwise to remove. The filter may or may not come out with the cover. If not gently persuade it out and clean.
It is again normally possible to see and check that the drain motor is free to rotate by hand/finger.
If the filter is perfectly clean when you check it, it COULD be that the drain motor is malfunctioning.
It is possible to check the operation of this motor by re-applying power, switching the machine on BUT EMPTY and immediately on to a spin cycle at which time the motor would, and should, be running.
Hope this all helps!
Cheers,
John C
Feb 06, 2011 | Whirlpool Washing Machines
Hi my washing mashine wont spin, and code 0E comes up on sreen and start button starts flashing PLEASE HELP THANKS
That is actually DE. (Drain Error) Open the small access door at the bottom left corner of the front panel. Use the small hose to drain the remaining water out of machine. Unscrew the big knob and pull it out to clean out filter. (If filter was clear, replace pump motor.)
Jan 01, 2011 | LG Washing Machines
Whirlpool Duet Sport--won't completely spin out, leaves water in the tub. I cleaned out the drain filter, it kind of works for 1 load then goes back to not spinning out completely.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Nov 03, 2007 | Washing Machines
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Whirlpool AWM5125/1 Front Load Washer Logo
211 people viewed this question
Dan Webster
Dan Webster
Sal De
