Question about JVC TH-M303 System
Auto shut off after powering on
The player worked fine, then i moved and after several months i hooked it up and when i turn it on, it waits a few seconds the powers off. need help as i cant afford a repair man or to buy another at present time.
  • dumbhunter Apr 09, 2008
    the problem i have is related to the 5 disc drive. it is out of timing just have not figured out how to adjust it to get it right.
  • 682 Answers
Please confirm your hooking is fine and try with good cable-make your volume master to minumum.and disconnect all speakers if the trouble goen you have a problem in your speaker and its cables.
if the problem remain the trouble will be in your system itself.and need to be fix in workshop.
Posted on Apr 06, 2008
  • mohamed eltoni
    mohamed eltoni Apr 09, 2008
    i will send to you any new data relating your problem as soon as i can get it.
NEC vt800 projector troubleshooting
That is a problem with the lamp. Replace it with a known good one.
Feb 27, 2013 | NEC VT800 LCD Projector
I got this computer from a friend of mine, and he hasnt used it in several months. I plugged the computer in, and the monitor and turned it on. It started up fine, I logged in, and then it asked me if it...
your computer have 2 complaints one. your computer have over heating problem of your cpu. so just remove heat sink and fan of ur cpu and clean after u must put 'heat sink compound on your cpu' after you can install heat sink back.
two, your computer is banded microsoft thats why when u loged on your pc. will ask automatic update so first you must log in to safe mode of xp ..click f8 button when u boot ur computer and login to safe mode.after you can install windows genuine remover you can download it from this site...http://www.brothersoft.com/removewga-download-62674.html..
Oct 06, 2011 | HP Hewlett Packard Pavilion a1016x PC...
My Stilletto 10 doesn't reliably record programmed talk shows. I leave it on and plugged into my car kit (yes, it is powered by a plug that stays on when the car is off) and when I come back it is...
Is it set for auto shut down? It took me months to properly record with this thing, frustrating at best. Now it's almost flawless. Go in to menu then settings then dock. In that menu you will see "Auto Shutdown". If this is on, your receiver will shut off after 4 hours only when plugged into the car dock. When on a home dock it will stay on. Turn this off and it will stay on until you shut down. Auto shutdown is the default setting. If for some reason you receiver is reset, you will need to check this setting again, because it will turn auto shutdown on again. Hope this helps.
Jul 17, 2009 | Sirius STILETTO 100 MP3 Player
Sandisk sansa clip mp3 shuts of and wont turn back on...
You can set the timer under Auto Power Off and Sleep settings to turn off the Sansa
player automatically when it is playing for a certain time.
1. Press Menu button to return to the Main Menu.
2. Move to Power and select it.
3. Select Auto Power Off or Sleep.
-Tha Mp3 Doctor
Nov 06, 2008 | SanDisk Sansa Clip MP3 Player
Region Error
please try if this helps:
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. turn off.
10. Turn player off then on again.
11. Player is now region-free.
Nov 02, 2008 | Samsung HT-X250T Theater System
Sony car cd player help!
Run a temporary direct power line to battery and see if it will turn on
Aug 08, 2008 | Sony Car Audio & Video
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
"Auto" always worked but now messed up; can't fix
I had same problem and eventually it died after degrading further a few months later. Other monitor works great...
Oct 27, 2007 | Videoseven V7 R19WPS 19" LCD Monitor
JVC TH-M303 System Logo
97 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
