Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Westell Versalink 327w -- can't change channel
The westell327w seems to be OK,however the wirless signal is weak. I thought I would try changing the channel to see if it improves my signal. I finally got into the router settings, but when I change the channel to 1, it defaults back to 6. Channel 6 seems to be a popular channel in my neighborhood, so i think it would be good to switch to a different channel. Why won't it allow me to change it?
Do I have to change the channel setting through the Verizon website and if so how do I do that?
I followed advice that I read on online about how I needed to get into the router settings, but they failed to explain that the default log in and password were "admin" and "password." I finally found it on another troubleshooting site. I got in, but it would not except any changes. I finally gave up.
A couple of ways later, I tried again and when I accessed the router settings it prompted me to change the default log in and password. After that, I was able to make any changes I wanted. Viola' !!!
~Caliwk
Posted on Feb 27, 2008
How to Disable ap isolation on westell 327w
Follow these four page guide to changing your 327W to bridge mode. This should solve your problem.
Changing your VersaLink 327W gateway to Bridge Mode High Speed Internet...
Dec 25, 2014 | Computers & Internet
I have a Westell 327w My companies laptop connects fine but my daughters laptop will not. Her computer can connect to other wireless just not ours. Any help greatly appreciated
hi
may your wirless is prodected by password
just folow the setp
click on wirless icon on screen try to connect it will ask you password
if you don't know the pass then
in explorer type your IP e.c. http://192.168.1.1
then it will ask router password just apply then you will able to see your wireless password from the router setting
May 30, 2010 | Westell Wirespeed VersaLink...
Port foward on a westell 327w
Ok this is an easy one, have a look at this tutorial at the link below it is quite long but easy to follow . http://portforward.com/english/routers/port_forwarding/Westell/Versalink327W/DC++.htm
Feb 10, 2010 | Westell Wirespeed VersaLink...
My westell versalink 327W router works when my computer is connected to it but it is not sending out a wireless signal
Try the following:
Check if wireless is enabled on the router.
Check if the wireless switch (if any) on the computer is on.
Check if the SSID broadcast is enabled.
Try a different wireless channel (6 or 11).
Hope this helps!
Nov 26, 2009 | Westell Wirespeed VersaLink...
My brother just gave me a Westell versa-link model 327w router. there isn't any instruction/opeartor's manual with it. is there a web site with instructions on how to go about hooking this up? Thanx Wayne
The 327w router is distributed by Verizon, an internet service provider. On their website you find tons of info on this model.
Go to the Verizon support page and enter
<westell versalink 327w> in the search field.
Furthermore here some interesting info for you:
Westell versalink 327w Quick Start Guide (700k)
Westell versalink 327w User Manual (10M)
Cheers
Critter
Dec 26, 2008 | Westell Wirespeed VersaLink...
Westell 327w channels
Type in http://192.168.1.1 in your browser window, this will take you to the Westell Home Page (your router). There are tabs at the top, select Configuration>Wireless>Basic, this will open a Wireless Operation Window. You will see Channel in the 3rd box down. Click on the arrow to change the channel, then click save at the bottom. Close all windows and X out of the browser.
Oct 18, 2008 | Westell Wirespeed VersaLink...
No wireless signal
Access the firmware page by going to your web browser and ener the following the address bar:
http://192.168.1.1 (assuming your provider hasn't changed this)
Mouse to "Configuration"
Click on "Wireless"
Select "Basic"
You will see the "Wireless Operation" field. Select "Enable" here.
I actually support this modem on a daily basis. If you have any more issues let me know and I will send you a link to a document with these instructions and screenshots.
May 14, 2008 | Westell Wirespeed VersaLink...
Poor wirless signal
Hi HHC,
You can try resetting the Westell to defaults, but pressing a thin pin, (Paperclip works great!) into the reset hole, in the back, and holding it in for 10 sec. You could also try using the lowest channel you. Most Westell's I have worked with have good wireless range, though. Test your laptop at a nearby hotspot, i.e. Starbucks. McDonalds, etc. If it is not the laptop, (Averatec laptops have horrible range!) and the reset don't fix it, have it replaced.
Good Luck!
Jan 07, 2008 | Westell Wirespeed VersaLink...
VPN through Westell Versalink 327w
do you have login access into the Modem/Router?
if yes, look for port forwarding and set it to your IP of your computer. open port 500 or what ever is required by MS fro the VPN
Nov 01, 2007 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
904 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Carlos Soto
Carlos Soto
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
