Question about Samsung PCL545R 54" Rear Projection Television
Colors out of place.
Hi again , I was looking for that setting on the menu screen but did not see it, would it come out under a different name or any thing different , cause i did try to adjust the color by trying to align the colors ont the screen were they have whit crosses top and bottom but that is way to difficult to do . Thanks again Buddy.
  • EMELY Feb 24, 2008
    I was just checking on the manual that you sent me thanks, but I didn't find anything for degaussing, have you found anything else in your notes? Thanks.
    Genius:
  • 3,587 Answers
Hmmm...should be a separate function, called degauss. that's standard on all of those sets.. let me check my notes again.
Posted on Feb 24, 2008
The colors doesn't look will, it look pale
You should always include brand name and model number when asking for help since the menu can be drastically different between sets.
Most later TVs give you the adjustments via the setup screens and most all contain adjustment points that allow you to change color depth, focus (soft or sharp) and brightness.Not knowing anything about your set, you will have find the menu for these on your own.
Jan 09, 2012 | Televison & Video
Hi, I'm having the same type of problem with my tv. It has the 3d look to the screen but it also has a large wavy red line through the top of the screen. Would this also be the result of the convergence...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 28, 2011 | Hitachi 51F500 51" Rear Projection...
Rainbow screen aiwa tv,, screen shows different colors like rainbow// brushing a magnet infront of the screen fixes the issue temporary
Picture tube is magnetized. Manual degausing is required. already you have done this.
Since you say it is reappearing, you have to check the following.
1. Relocate the TV or relocate if you have placed any tower speakers
or home theater speakers close-by.
2. Check whether auto degauss functioning OK. In the MENU
check whether you switched off auto degauss option. If it is OFF
enable it to ON.
3. Finally re orient the direction of your TV and watch the rainbow
effect. Switch OFF TV, wait for 20 mts, and again switch ON.
Repeat the process. It should disappear.
Magnetic toys or any other devises using magnet will cause this problem.
Aug 11, 2010 | Aiwa TV-S2011 20"
Green tint to screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 21, 2010 | Hitachi 42V710 42" Rear Projection HDTV
Approx 40% of right side of screen flickers,non-stop
This problem is normally resolved by degaussing your monitor?.
This option is found normally on the control panel buttons of the monitor. Just press the menu option and look for the Degauss option.
You should have the option someplace on the monitor controls.
It will disperse any magnetic build-up that has taken place on your monitor over time.
Also check for any electronic items if they are placed too close to your monitor as the magnetic field from other items might be the reason for the same.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Jan 05, 2010 | Acer Computers & Internet
Wavy picture at bottom half of screen looks like two different colors, top half convergence looks good bottom half of pictute looksbad . Can it be vertical coil on two piture tubes not being drivendue to...
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Oct 26, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
My laptop screen started to look like an old tv with a distorted image. The colors look different, and there are pink and red lines going across. The laptop seems to function o.k. but the image is...
This definately is hardware issue.
2 options for you.
1. open the screen and check if the signal cable to lose. if you can out it in right place you can fix this onyour own.( I would recommend this only if you have prior experience in troubleshooting laptop hardware)
2. otherwise see the hardware vendor.
Sep 09, 2009 | Toshiba Satellite A100-S8111TD Notebook
Convergence for toshiba 50h82
Either mode is fine...just save your session when done!
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Nov 16, 2008 | Toshiba 50H82 50" Rear Projection...
Convergence colors gone bad
im wondering if there is a degause (spell check) setting that can be used after all this work i know it works on comp screens it
degause is supposed to power screen with a surge of power to return it to normal stasis
Apr 23, 2008 | Apex Digital GB5108 51" Rear Projection...
Iverted Screen Color on my HP laptop
hot4teacha,Great name.
By inverted colors, could you explain a little better?
Do you mean it looks like an x-ray?
Jan 18, 2008 | Computers & Internet
Samsung PCL545R 54" Rear Projection Television Logo
24 people viewed this question
Jerry Greenberg
Jerry Greenberg
