Printer will not print
Printer is plugged in but registers "Offline" Canon1320. Will not receive the signal to print. Toshiba plaptop. Always did before.
    Master:
  • 518 Answers
From the Control Panel, remove all printers. Unplug usb cable. Reboot. Install drivers. Plug in usb cable.
Geno
Posted on Feb 25, 2008
Hp laserjet 4000 printer always saying "off line" and not printing what could be the problem
Please Clarify, does it say offline on the printer itself or on your printer driver. If it says offline on the printer itself, normally pressing the go button should put it online. However, at the age of that printer the buttons could be dirty/worn out, I have had control panels fail quite often as of late. If it is saying offline on the computer driver then that is a whole different set of issues and I would need to know what operating system you are running.
Jul 20, 2014 | HP LaserJet 4000 Printer
To change print status "offline" to "online
Go to devices and printers to see if your printer is set to default. Make sure the printer cables are plugged in tight. Offline means it is not getting a signal . In Case You Still Having Problem Then Follow Us For On : Brother Printer Support
Aug 01, 2011 | Brother Office Equipment & Supplies
I have an Canon MX850 printer -- when I try to print anything using the BlueTooth connection, it says the printer is offline. How do I set it "online"? It is plugged in. It is the same as it has always...
Hi Cynthia
Any recent changes like moving cabinets or furniture?It doesn't have to be anything large,a Blue Tooth connection is really short range and it doesn't take much to interrupt the signal.
Take a look around for anything that may be out of place or new.
Bob
Aug 22, 2010 | Canon PIXMA MX850 Multifunction Printer
Windows 7x64, HP8000, Offline
Disconnect the printer.
Click Start
Click Control Panel
Click Printers
How many "copies" of the same printer are installed?
Delete them all
Connect the printer, and let Windows "add printer".
Jul 18, 2010 | HP Office Equipment & Supplies
DOES ANYONE KNOWS HOW TO SOLVE MY PROBLEM?HERE IT IS..IT ALWAYS OFFLINE MY PRINTER EVERYTIME i print it,he goes offline and the print is unabale to print can anyone help me?to fix..thank you. im using HP...
when you hook up your printer to your pc via USB...can the computer detect your printer? does it prompt out any msg such as new device is installed and ready to use or did it ask you to install the printer driver?
if your pc can't detect your printer, replace the USB cable and try again.. and try to plug into a different USB port on your pc.. and if all fails, then most probably your printer main board is faulty...
May 28, 2010 | HP DeskJet F380 All-In-One Printer
Printer won't print it always it is offline
Perform the steps below and check
(1) Click "Start" > "Run".
(2) Type "services.msc".
(3) Click "OK".
(A window will pop-up with so many services listed)
(4) Locate and Right-click "Print Spooler" entry and Select "Restart" from the drop down menu.
(5) Now please restart the computer.
* Click Start > Control Panel > Printers
* Select the Printer you are using
* Right Click on the Printer Icon
* Select Use Printer Online
Now check if you are able to print
May 18, 2010 | Office Equipment & Supplies
The printer is always offline
try this go into control panel click on printers to open all available printers. make sure your printer is set to default. right cilck on your printer a menu will appear look for use printer online and click on it if its a setting this will fix it. if not uninstall and then reinstall the printer software with your antivirus disabled
Oct 25, 2009 | Lexmark All-in-One Printer with PictBridge
Printer status says offline, and we can not print on laptop
Hi!
If you're offline with the printer, you definitely won't be able to print.
I'm assuming you're using Windows XP here. Most Windows products will be similar...
On the laptop, click on the Start button, then Settings, then Printers and Faxes. Find your printer in the list, right-click on it and click "Use Online" or uncheck the "Offline" box.
Good luck! Remember to rate the solutions!
Aug 10, 2009 | HP Officejet 6500 Wireless All-in-One...
TOSHIBA DP80F always offline.
Try Unplugging your printer waiting a minute and reconnecting it!
If that doesn't work you may need driver updates!
Driver Update Software Recommended: @
http://www.driversupdate.org/?gclid=CKjWiPnXyZgCFQECGgodC1QR0g
I'd go to the above site and click on DOWNLOAD NOW. This will install a prized program to update and install all your drivers. The program will appear on your desktop as ParetoLogic DriverCure. Run it often to keep all your drivers up to date!
If this doesn't work please get back to me and let me know!
jack
Feb 09, 2009 | Toshiba DP80F Printer
OFFLINE PROBLEM
disconnect USB, go to RUN and type in services.msc and then find print spool and right click, then choose restart .plug in usb
Mar 02, 2008 | HP PhotoSmart C4280 Laser Printer
300 people viewed this question
jasbo
jasbo
