Question about Whirlpool RF369LXPQ Electric Kitchen Range
Whirlpool Standard Cleaning Electric Rang Model RF315PXKQ
Subject oven does not heat. The burners work, all lights come on; however, when you press bake for oven and start it only goes through to motions as if the oven is heating.
My son-in-law has replaced elements and checked them, they are fine.
He can attach the voltage by hand and the oven will heat. Can you help me? Thanks.
    Genius:
  • 3,422 Answers
Can you please tell me if you have replaced the thermostat?If not then please do that.
Waiting for your reply.
Posted on Feb 24, 2008
Heating elements on whirlpool electric range do not work
They may just be loose,try push the heating element in to socket,Or remove and check ends,may need cleaning to get good connection.
Dec 25, 2012 | Whirlpool Kitchen Ranges
Whirlpool electric stove oven burners won't heat cooktop works
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 21, 2010 | Whirlpool Kitchen Ranges
Oven won't heat, display out, gas burners on stove
Hello, you will probably need to pull it out and put it on something. Make sure the breaker is off to it before you test it. There is a thermostat in the very back that could be bad,check for continuity on that. Also check for continuity on the bake and broil element terminals itself,even though you have checked it to ground. If those check good,then the problems is in the control board.
Thanks
May 31, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
BROILER WORKS, BUT OVEN BURNER DOES NOT LIGHT Model SF362LXSQ
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
ggdh
Feb 16, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Heating elements
I have a Whirlpool super capacity 465, the surface light for the burners comes on, the burners don't heat up, nor does the oven,(the light that says oven is on does not light up). I checked the main circuit breaker, that works. Are there any fuses in the range that would need to be replaced?
Thank-You,maddie
Feb 01, 2009 | Whirlpool GR460 Electric Kitchen Range
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Estate Range #TE5400PXHQ0
MY SELFCLEANING WHIRLPOOL OVEN CLEANED ABOUT 30 MINUTES AND THEN STOPPED AND WENT INTO E2 AND F1. THE DOOR IS LOCKED AND WON'T OPEN. WE HAVE TRIED EVERY THING THE BOOK SAID AND NOTHING HELPS. DO YOU HAVE AN ANSWER?
Dec 20, 2007 | Whirlpool RF368LXKS Electric Kitchen Range
Whirlpool RF369LXPQ Electric Kitchen Range Logo
315 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
