Question about Video Cameras
JVC CAMCORDER KEEPS ON GOING ON TO E03 UNIT IN SAFEGUARD MODE EVERY TIME I TRY AND USE IT
  • 1 more comment
  • Recall2003 Mar 26, 2008
    Hello, I have a JVC Compact VHS Camcorder Model# GR-SXM 340U and it's give me the same error message. It's says E03 Unit in Safeguard Mode. Would anyone know what the deal is ? Thanks,,Bill
    billydrowe@embarqmail.com
  • EDSS310 Sep 05, 2008
    2days after I used the camcoder. I went to rewind the tape but it gave the error E03 - SAFEGUARD MODE - anyone knows how I can fix it ?
  • Anonymous Nov 04, 2008
    I have the same problem. I beleive that the pinch roller has come off. I found what looks to be this piece upon opening ejecting the cassette.
    It looks to be a $.50 peice that has now made this $400 (original price) camcorder essentially a paperweight.
    If anyone has any advice how to fix le me know!
E03 is a tape winding error. I had the same problem. Try a new tape. That's all it took for mine.
Posted on Jun 03, 2008
It keeps saying it in safeguard mode
my jvc camcorder kep.s saying unit is in safeguard mode eject and reinsert tape have done this a dozen time still show,s same thing on screen would appreciate help thank you larryd i
Feb 13, 2011 | JVC Video Cameras
JVC mini GR-D23EK Unit in SAFEGUARD mode E03 how to correct it
Hello. What I've found is that in dealing with the error codes your choices are very limited. You can try removing the battery and power supply for a while. This might clear the code, however, failing at that you'll be forced to send in the unit for repair--you are absolutely not alone in getting this type of problem--definitely get a quote first and keep "do I want to replace this unit" in the back of your mind....This is a JVC problem.---Rick
Sep 16, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
Playback moe
Could be a DEW sensor. It could cost about $90 - $116 to replace that sensor
Dec 31, 2008 | JVC COMPACT VHS-C CAMCORDER
Error E03 -
I tried Tapping on side of Camcorder and I worked, after 2 or three times while message appeared.
Oct 19, 2007 | JVC GR-DVL100 Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
E03 safeguard mode
look for a tiny pinhole and insert a pin while powered up to reset
May 27, 2007 | JVC Cybercam GR-DV800US Mini DV Digital...
Video Cameras Logo
1,075 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
