Question about Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum
Wind tunnel supreme sounds very loud
We recently bought a wind tunnel supreme. it is very loud, and sounds like its going to come apart any moment.. the sound seems to be coming from the base. Is there anything we can check?
    Problem Solver:
  • 8 Answers
Something mite be lose in the motor take to the nearest hoove repair store and have them check the motor
Posted on Feb 22, 2009
Be sure, especially if there is anyone with long hair in your home, to do this at least once a month:
Remove the bottom plate and take the brush out
Unscrew the caps at the ends of the brush and remove any hair and debris before replacing them
Remove the belt and then remove any hair wound around the drive shaft
Posted on Mar 02, 2008
  • 1,673 Answers
You can take the bottom plate off and check the belt and brush roll. if they look ok, then you may have a bad motor. But if this is less then 1 year old, then it is under warranty, you can take it in for warranty repair. There is a 1-800 number by the model number plate you can call to find out where you can take it to near you.
Posted on Feb 28, 2008
Hoover 30600 max wind tunnel less than a year old makes a whistling noise
Ours did too. I bought a Dyson.
Check for gaps in the hoses and in the wind tunnel canister. Something is not sealing properly.
Nov 11, 2016 | Hoover Vacuums
Loud rattling noise and no suction
You have something that's been sucked up into the floor cleaning part of the machine... then clogged it off. Be persistent and you should be able to find it and get it out..
Nov 04, 2013 | Hoover Vacuums
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
I have a Hoover Wind Tunnel Supreme mach 3.9. It
Check the filter above the dirt tank. If you take out the dirt cup and look where in slides into the machine, there is a filter that is probably dirty. It can be cleaned or replaced
Oct 08, 2009 | Hoover Vacuums
Sounds like a bad motor, you have a years warranty on this, take it in for warranty repair. You will void the warranty if you mess with it.
May 08, 2008 | Vacuums
Hoover Wind tunnel supreme, loss of suction
posted by bazballfan on May 01, 2008
Hello, I purchased two of these models in late 2007 and after changing the bags on each of them I have little to no suction with the vacuum. The hose is fine and I have taken them apart and there is no obstruction in the hose or in the base.
These worked so well and now they don't do anything. The bag isn't filling much and the simplest things can’t be vacuumed up
Please help me to fix this
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U5450-900 Windtunnel Supreme Vacuum
Sorry you are having a problem, it sounds lie you have done almost everything, but just in review it could be some of these problems:
Belt change – every 4 to 6 months
Are the brushes in good shape
Where does your suction drop off
Is the bottom plate securely on the bottom
Are there any gaskets that are broken or leaking
Is the bag installed securely
Did you check for any clogs or obstructions
Is the filter clean
Feel free to contact your local vac dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Hoover U5450-900 Windtunnel Supreme Bagged...
Edge of carpet went into carpet; was removed, but now all rollers on the unerside don't function.
You didn;'t say what the problem is, but I assume that the brush roll is not turning. Take of the cover over the brush roll, then you can get to the brush roll and the belt. The belt probably came off or broke. Best to replace the belt.
Jan 07, 2008 | Vacuums
Hoover wind tunnel vacuum cleaner shuts off during use
Check the inlet down by the brush roll to make sure it isn't clogged. If not and the hose isn't clogged, then probably the thermo protector (part #28382093) maybe bad. It is mounted near the motor. Could be motor Part #43576188. But I would suspect a clog in the inlet or hose, or the thermo protector has gone bad.
Dec 25, 2007 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover Wind Tunnel
what probably happened is you swapped end over end when you replaced the beater brush. anyway go to thehooverstore, find your machine and you'll see an exloded diagram of your machine.
Aug 18, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum Logo
191 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
