Question about Whirlpool GU2400XTP Built-in Dishwasher
I believe my dishwasher is haunted!
Our 2400 is starting by itself. It works fine when we run it but when it is just sitting there, it starts up. We have to leave the door open or it will run a full cycle. Even with the door open, the lights stay on and flash and blink like it is trying to start up. We have thrown the circuit to try and reset it but that didn't do any good. The delay cycle isn't activated. Any idea why this would happen and what we can do to fix it? Thanks!
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds like you have a stuck key in the control panel, you would need to replace the keypad, which comes as complete console w/active overlay(check your manual sometimes extended part warr on electronic model
Posted on Feb 26, 2008
Brand new whirlpool dishwasher starts on own
Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
My miele g680 dishwasher did have a flashing intake/drain I cleaned it seemed to be working fine, then everytime I try to start it the softener light comes on with no further washing activity.
that is just an indicator that your salt is low. it will stay on until you refill the water softener with softener salt. it will not affect the dishwasher to run it without the salt. the water for your final rinse will not be softened.
Apr 06, 2012 | Miele Dishwashers
The Whirlpool Dishwasher GU 2400 won't staart
Sometimes I have to push the cancel button on my Kitchenaid and start over and push the selection buttons again. and then push start. Don't know if this will help.
Jan 07, 2012 | Whirlpool Dishwashers
My Frigidaire dishwasher will not start. It was working fine about a month ago. The lights on the panel are working and I had the water line checked and it is o.k. I cannot find a serial number but the...
My Frigidaire 500, 1100, 1400, 1500 & 2400 Series Dishwasher was purchased a month ago and it will not start either. The 8 second lock under "Heat Dry" is lit, but nothing happens when you press any of the other buttons. Any ideas?
Mar 27, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Sishwasher not used for months. Now motor only
Disassembled dishwasher. Some plastic scraps had shredded and wound itself around the pump impeller axis. It was preventing the motor from turning. Upon removal diswasher again worked fine.
Oct 22, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Dishwasher lower spray arm falls off
These parts can be replaced easily and reasosnably cheaply for example the top spray arm is about £20.00p. But you need the back water feed tube as well as the lower spray arm which should come as one package. (depending on model i'm going by bosch). You shouldn't have to pay more than £30.00p + p&p. Hope this helps.
May 19, 2009 | Dishwashers
Etv20
mabye its haunted oooooohhhhhhh!!!!!
Oct 23, 2008 | Emerson EWF2004 20" TV
Kitchen Aid dishwasher won't start
If the power indicator is on check the latch as alot of the kitchen aid dishwashers wont start if the latch is out of alignment.
Jul 02, 2008 | Dishwashers
Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
FIX:
I started the rapid advance service diagnostic feature:
1.Close dishwasher door
2.press "Hi-Temp Wash"
3.press "Energy Saver Dry"
4.press "Hi-Temp Wash"
5.press "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Jun 13, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Whirlpool GU2400XTP Built-in Dishwasher Logo
136 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
