Question about Kenwood KAC-7202 Car Audio Amplifier
Turns on for a second then truns off
The amp turns on for a second and i see the triangle turn red then it turns off
  • Anonymous Apr 03, 2008
    the amp will turn on (red triangle lites) for about one second, then it will turn off, the fan will continue spinning, but the amp is off.
  • 77 Answers
After reading thru many posts I have found out that this problem your having is the same exact problem I had. Amps fan is the only thing working, no light either but it used to come on for a second. Anyway it turns out I found one bad zener diode. Diode D9 1ss133.
It's over where the fuse is located, in the power section. This amp had me stumped for a month almost 2 months. Then one post led me to diode check which was my next move after I ruled out that all transistors were good. So, this is the problem. Use a digital volt meter and find the bad zener diode. They are small kinda orange in color with a yellow stripe on one end. You'll see them it's basicly the only things in that area next to the coils/chokes or loads if you wanna call them. Good luck. My amp works great now, playin as I type.
Posted on Feb 09, 2009
  • 640 Answers
The amp is going into a protective state.You either have a bad resistor,capacitor or coil shorting internally in the amp.If you open it up you may be able to tell right off the bat of the bad component as it would be burnt or you will need a meter to troubleshoot it.
Posted on Feb 24, 2008
How do i unlock my nexus 7 when its on the screen with android robot laying on its back?
Android robot laying down with a red triangle having an ... > Forums > Featured Forums > Android Lounge
Mar 24, 2013 - 14 posts - ‎7 authors
Whenever i try to turn my android tablet on it displays android robot laying ... an exclaimation mark in a red triangle and dont let me proceed to its desktop . ... and holding it until it turns off and then turn it back on can revive it, ... no command error ' Android Forums
19 Jun 2014
HELP-Tried Recovery Reboot, Red Triangle w ...
15 Jan 2012
More results from
SOLVED: android guy on his back - Nabi Jr - iFixit Oct 31, 2016 - my android guy on the screen is laying on his back with the stomache door ... Android recovery mode" and a few seconds later an Android robot ...
How to Fix The Dead Android and Red Triangle Error Symbol - YouTube
? 1:44
Oct 5, 2016 - Uploaded by Gauging Gadgets
Meaning of Green Android laying down and a red triangle with an exclamation point inside it: •If there is ... All ...
How to Fix The Dead Android and Red Triangle Error Symbol Android Recovery...
Jul 07, 2017 | Tablets & eReaders
VCR is turning off within seconds of when it's turned on, there is a red rectangle on the screen which does not say anything like it being locked, & a wheel that is continuing to move while it's o
It looks like the red triangle might be an indication that there is a fault. It could be something to with the mechanism. I would take a look inside the unit by taking off the top cover. The unit shuts down to prevent further damage.
Feb 16, 2014 | Televison & Video
Turn on ps3, light truns green for a second then turn red with a beeping noise?
I had this problem not a few months ago. It is the beginning of the yellow light of death syndrome. Sony can repair it if it is in warranty, or there are independent chains that also do repairs. The price to repair mine (replacing the optical drive) was $130.
Mar 12, 2011 | Sony Playstation 3 (PS3) Console
Power is hooked up. Ground is connected. Both subs are connected. The triangle light is red, and there is now sound. All wires are hooked correctly...
on most amp red isnt good that means it in protection mode try turning your setting on the amp down all the way and turn the volume down tell you can get sound out of them then turn up the volume to were you would to them most and set the to what sounds the best but make sure the light doesnt dim down when the base hits
Jan 16, 2011 | Kenwood KAC-7204 Car Audio Amplifier
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Ps3 turns on then off
does it go yellow than blinks red if it does either experinceing vennelation problems wich I cant help you with or 2.the ps3s hd is fried in wich you are ****ed sory
Sep 30, 2009 | Sony Playstation 3 (PS3) Console
Sharp Al 1631 red triangle is on
dear sir ; the red triangle symble means need toner, you just put new toner the light will go away. good luck and
Dec 18, 2008 | Sharp Office Equipment & Supplies
you will want to turn your radio volume up till you hear distortion then trun it down slightly. then turn your amp up until you hear distortion then trun you amp down slightly.
Aug 06, 2008 | Alphasonik PMA600HC Car Audio Amplifier
Red Screen and then turns off
your red CRT is most likely shorted and will need to be replaced. If you need more assistance please let me know.
Jul 04, 2008 | Sony KP-46WT520 46" Rear Projection...
Kenwood KAC-7202 Car Audio Amplifier Logo
236 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
