Question about Lexmark X83 All-In-One InkJet Printer
Lexmark x83 carrier stall
The error reads carrier stall, press power key. when power key is pressed, the printer cartridges SLAM, with alot of force, all the way to the left. The the error reappears. The cartridges slam so hard the color cartridge pops out. PLease help.
Leanne
  • 4 more comments
  • wiifus Feb 26, 2008
    same problem
  • delcasse Mar 11, 2008
    When the power switch is pressed ON, the support cartridge SLAM with a lot of force and go all the time to the left side. After few seconds, appear the message in French "Support Bloqué, App touchez Alim"
    I tried many time but nothing change.
    Could you help me to solve this problèm.
    Thank You in advance.
    Didier Delcasse
    didier.delcasse@atr.fr
  • Anonymous Jun 15, 2008
    COMPUTOR WAS SHUT DOWN COMPLETLY FOR 6 MONTHS , REPLACED INK CARTRIDGES AND PLUGGED IN THE PRINTER. WHEN POWER BUTTONWAS PUSHED THE CARRIER SLAMMED TO THE LEFT AN MESSAGED ADVISED CARRIER STALLED, PRESS POWER BUTTON; SAME PROBLEM OCCURED AGAIN ; EVEN AFTER UNPLUGGING AND REPLUGGIG THE PRINTER.
  • Anonymous Jul 05, 2008
    Carrier Stall is posted as the problem. I have pressed power key. but nothing happens. Problem still exist.
  • LAURA DEE Jul 06, 2008
    I have the same problem :just installed new cartridges and the unit keeps slamming and indicates that the carrier is stalled help please anyone ?????
  • Anonymous Feb 10, 2009
    installed new ink cartridges and carrier keeps slamming hard and ink cartidges won't center
    Genius:
  • 2,035 Answers
Http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
To check the cartridge carrier:
1. Unplug the printer.
2. Move the cartridges to the left by hand and then take them out.
3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
1. Remove any other devices attached to the USB/LPT port.
2. Uninstall the Lexmark printer.
3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
4. Reinstall the printer.
Posted on Mar 20, 2008
Message reads "cartridge short press power key"
The error indicates that one or both of the cartridges has a short circuit. Please follow the steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 11, 2011 | Lexmark X83 All-In-One InkJet Printer
Hello there.
I have checked lexmark's website on troubleshooting this problem for you.
As per the link here we need to try the following steps to resolve the problem.
Carrier stall" Error and the Carrier Slams in the Printer ID:ENUS12078 null.gif null.gif null.gif
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
  6. If the problem persists, you may need to contact Lexmark Technical Support.
Let us know how this goes and we can assist you futher, if the printer is damaged and is under a year old, lexmark may be able to repair or replace it for you.
Hope this helps.
Jun 16, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark x2600 is blinking ej
The EJ error on your printer indicates that your ink cartridge carrier has stalled. Open the printer cover and clear the mechanical jam, then press the power button. Try to reseat your cartridges and make sure it's properly inserted in the carrier.
Apr 04, 2011 | Lexmark X2600 InkJet Printer
After replaceing an ink cartriage every time I turn the printer the ink tray slams to one side then all the way back I gert an error message to start it again and slam bam. I hope you can help.
The encoder strip may have come out of the sensor slot. Turn off power, slide cartridge carrier to center, place finger on each side of encoder strip which runs behind the carriage and push the encoder strip down and back up, slightly back and forward if necessary to get it into the sensor slot which is located behind carrier. If it is in slot, sliding the cartridge carrier back and forth to see if therre is movement. If so repeat.
Dec 26, 2009 | IBM Lexmark X83 All-In-One InkJet Printer
Carrier Stall is the error
Please do the following..
Thank you....
Jan 26, 2009 | Lexmark X83 All-In-One InkJet Printer
Printer problem
Hi I went to lexmark.com and they told me to unplug usb and power cord. wait 30 seconds. replug, press menu button until manitenance shows up and select. go to self test, select. it should print something. if not take out cartridges and redo steps. it did work for me
Feb 18, 2008 | Lexmark X83 All-In-One InkJet Printer
Can not get the ink cartridge out
Jan 14, 2008 | Lexmark X83 All-In-One InkJet Printer
Error 1200, printer carrier stall
check printer belt for missing teeth if none are missing lubricate carrier bar(big siler bar that ink cartrides trvel along) with 3in 1 oil with power off then back on to retry
Jan 06, 2008 | Dell 922 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
1,243 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
