Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Can't clean out a part; need help
Behind the floor nozzle window neer the top narrow part, there is a dark gray plastic piece that is clogged with hair and lent. I cannot see how to remove this piece to clean behind it. Please advice. Removed two small phillip scews on each side at bottom of nozzle window but plastic face would not come loose. Thanks for your help.
David
    President:
  • 1,673 Answers
The nozzle will seal very tight along the sides, pry up with somethin like a flat blade screwdriver to pry it loose. When you re-install it, make sure the 2 tabes at the top edge of the window snap into the slots first before putting it all of the way down. If you don't then the bucket will sit up slightly and won't suck up the water.
Posted on Feb 28, 2008
  • premo330 Dec 23, 2010
    thanks so much! this helped alot i had to first google what the hell the floor nozzel was then google how to remove it. after about 15 minutes of googling this i was almost ready to give up untill i came across your post. i would have ended up probably breaking the nozzle window in half tryin to pull it up. very helpfull!. thanks
My carpet cleaner bissell pro heat wont extract the water from the carpet
1) Remove the Tank-in-Tank Assembly and place your hand over the motor intake valve. This valve is located next to the Floor Nozzle gasket (at the top of the Floor Nozzle window) and behind the SmartMix Bottle. If you feel vacuum-like suction at this area, your suction power of the unit is working but air is escaping at some point. If there is no suction at the motor intake valve your machine will need to be inspected by an Authorized Service Center Technician.
2) It is possible the Floor Nozzle on your machine is inserted incorrectly. This would directly affect the suction of your machine. Please follow the directions below for removing and replacing the nozzle.
Before starting, please be sure the machine is unplugged and the machine handle is reclined.
To remove the Floor Nozzle window, first detach the Phillips head screws located at the base of the nozzle. Then, remove the Tank-in-Tank Assembly. Next, pull forward at the top of the Floor Nozzle window to release the tabs of this window from the receiving holes of the machine. This window is designed to allow access for cleaning.
When replacing the Floor Nozzle window, please be sure the tabs at the TOP of the nozzle are properly inserted into the receiving holes provided. If you do not have the tabs in place properly, the suction power of the machine could be affected.
Rotate the window down into place and replace the screws.
3) Ensure that the Ready Tools knob (diverter knob) is in the proper setting and the valve opens and closes freely. Ensure the black foam gasket is in place under the valve.
4) Check to ensure the Tank-in-Tank assembly is seated properly and that it is not full of dirty water. (If this tank has a drain cap, make sure it is in place and that it has a black o-ring).
5) Check the float and baffle to ensure they are properly installed on the Tank-in-Tank. The larger square portion of this part should be below the clear baffle of the tank with the red flag portion of the float resting on top of the baffle.
6) Check the Tank-in-Tank and lid for damage. Is the lint screen clogged? Make sure the lint screen is in place on the tank lid and not placed into the motor duct. Also, clear the holes on the lint screen.
7) Check to see if the upholstery hose has suction. If the hose has suction and the floor nozzle does not, check the diverter valve to see if it opens and closes freely. This can be seen through the Floor Nozzle window as you switch the diverter knob from the floor to tools setting.
If these suggestions do not solve the problem, please have a technician at a local BISSELL Authorized Service Center inspect your machine. BISSELL supports your machine with a one-year warranty for any defective or malfunctioning part.
Nov 22, 2010 | Bissell 8910 ProHeat Clear View Upright...
My bissell powersteamer isnt suctioning the water
Please try the following suggestions to see if you can get your machine suctioning properly:
Nov 05, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
The cleaner no longer vacuums up the water. I have to use the tool device to get the water up. marleneodlekemp@hotmail.com
Try the following suggestions to see if you can get your machine suctioning properly:
Aug 11, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Vacumm not working shampoo the rug but does not pick up dirty water
Aug 04, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
The cleaner will not remove the water from the carpet. I have cleaned as much of the cleaner as I can reach. Where is it stopped up or what is wrong
If these suggestions do not solve the problem contact BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Aug 03, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My power steamer seem to be putting down water and scrubbing but it's not picking up the water it puts down. Also, it doesn't seem to be using any of the cleaning solution
Trythe following suggestions to see if you can get your machine suctioning properly:
Jul 14, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
The bissell proheat will not suction
Jun 15, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
No suction
Jun 15, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
My bissell will not **** up water
May 19, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
I just got the steam mop but it came without instructions, I don´t know how to assemble it. I´m not sure if I´m missing pieces
There should only be 3 basic pieces to this machine. The body housing, the top handle and the floor nozzle. The handle attaches to the body with a bolt and a nut and then the floor nozzle is just pushed into the body housing. That should be it.
Nov 30, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
96 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
