Question about HP Compaq nx6110 Notebook
Volume control Does the nx6110 have a volume control on the keyboard? Thank you
  • Audrey Diana Feb 25, 2008
    No, That doen't work.
    Thank you anyway
  • marcus 123 Mar 18, 2008
    Got same problem with Compaq nx6110 as there is no volume control on side, what keys control volume as with other laptops?
Do you not just use the shift key at F3 to turn down and F4 to turn up???
Posted on Feb 24, 2008
How do i change my volume and where is the fn key in this keyboard
    Is it possible to control the master volume with some keyboard shortcut? I would prefer it to be without a use of some additional software.But if it isn't possible then the software should be pretty light-weight and not consume a lot of CPU/RAM. Thank you for your help.
    PS: I DON'T intend to buy a multimedia keyboard for that.
    Yes,you can create a Master Volume Shortcut and also assign a Shortcut Key.
    Right click on a empty area on desktop, and click on New and Shortcut.
    Paste the following in to the location of the item area:-
    %windir%\System32\SndVol.exe -f 49825268
    Click Next button and give a name to the Shortcut and click Finish.
    Now You right click on it and select Properties.
    Click Shortcut tab.
    Assign your desired shortcut key like F8 or F9 in the Shortcut Key area.
    Click OK/Apply.
Is There Keyboard Shortcut For Volume Control
Mar 08, 2015 | ASUS KB73211 Wired USB Keyboard OEM
Need to know where the volume buttons are on k120 keyboard?
I think you got a non-multimedia keyboard, so there are no options for volume control, here is a way to do it, you can try it. How to keyboard shortcut volume control windows 7
Apr 03, 2014 | Generic LogiTech K-120 USB Wired Keyboard
Pxe-e61 on my hp compaq nx6110, wont boot up!
If your laptop used to freeze up at random, the mouse and keyboard did not respond at some times or you experienced longer and longer boot times with the HP logo on, then your laptop is suffering from a motherboard failure. The options are either to get a new motherboard, or repair the one you have. Here's a great repair tutorial for non booting or random freezeup HP nx6110. The repair does not require any tools, except for a Torx screwdriver, and it usually takes about an hour to do the fix. If that doesn't work then you'll have to use a hot air gun and do a reflow of the FSB chip.
What happened is that in time, the FSB controller chip lost contact with the motherboard and since the FSB controls the hard drive, dvd, keyboard, mouse and so on, the laptop cannot boot. The repair tutorial will help you to re-establish contact between the chip and the motherboard, but you will have to open up the laptop. It's not a difficult repair, but if you're not very handy with tools, you may take the laptop and the tutorial to someone that can do the work for you. It's better to be safe than sorry.
If this post was informative and helpful, please vote with a Thumb Up. Thank you.
Jan 19, 2011 | HP Compaq nx6110 Notebook
Sound abscence
go into volume control and see if the settings for the speakers are turtned up and on. double click the volume icon and it will open the volume properties. go from there.
Nov 24, 2009 | HP Compaq nx6110 PC Laptop
I have HP compaq nx6110 laptop with fogoten BIOS password what should i do?
You will need to:
  1. Turn off the laptop.
  2. Remove the battery.
    Remove the two screws that secure the keyboard.
  3. Remove the keyboard.
  4. Remove the battery "RTC".
  5. Leave it in this state for 15 minutes.
    Then connect only the main power cable WITHOUT the battery installed.
  6. Power on the laptop, and the RESET is done.
    Power off the laptop.
  7. Reconnect the “RTC”.
  8. Re install the keyboard.
  9. Re install the battery.
  10. Make sure there are no spare screws.
  11. Power up the laptop and continue to use.
Sep 09, 2009 | HP Compaq nx6110 PC Laptop
No sound from sound card
Go to control panel. open System. Click on hardware then click on device manager. Check if you have any icons that have a question mark or an exclamation point. If you do then doublecheck the name if its your audio. If it is then Reinstall your audio driver. If not check your volume by double clicking on the volume icon near the clock. If its set to on go to your audio properties check your settings. If everything still does not work then have your hardware checked already by an outside technician.
Jun 01, 2009 | HP Compaq nx6110 Notebook
Keyboard volume control???
Based on years of using computers and seeing many keyboards when I used to do IT work, typically it's not standard for many keyboards to have that, sometimes different keyboards might have an "fn" key though which will allow for other options displayed on keys such as volume up or down. I can suggest a keyboard for you with the media keys if you really need it, anyways I hope you're having a good day, and that I helped somehow.
-Jeremiah HP K1500 Keyboard
Jul 30, 2017 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard not responding
Boot in safe mode
>control panel
>Printers and other hardware
>check to see if is has been disabled
??>does you mouse pad work
>If no plu a USB mouse in 1st before you boot into safe mode
Aug 28, 2008 | HP Compaq nx6110 PC Laptop
HP Compaq nx6110 Notebook Logo
249 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
