Question about Stoves Newhome ECH600MXa Electric Kitchen Range
Exploding stove burner
The coil on one of my stove burners exploded while cooking. It is a very old stove and I don't know if we (tenants) can fix it or if a new stove is recommended. The model is at least 15 to 20 years old.
  • Anonymous Apr 28, 2008
    I had the same thing happen tonight. I was cooking on one of the burners and the heating coil exploded putting a hole through my skillet. Thankfully the fire went out on its own, and I turned off the breaker to the stove, but as I live in an apt I don't know if they will replace it. It's an old GE model from the late 70's/early 80's.
  • Ron Coons
    Ron Coons May 11, 2010
    cant see why it wouldn't be replacable, do you have a manufacture of a model number to look up parts for it
  • 132 Answers
SOURCE: whirlpool electric range burner exploded ''on'' light on always
Hi There,
While the stove is unplugged remove the bad burner from the stove and set the bad burner's control knob to the "OFF" position. Now plug the stove back in. If there is a problem it should trigger the breaker and shut off the stove. If you are not comfortable doing this you might want to ask someone.
The explosion was due to a shorted burner element and once it is removed there shouldn't be any more problems. I hope this was helpful and I hope you get your stove going again.
Posted on Mar 26, 2009
Amigaman
  • 248 Answers
SOURCE: Whirlpool electric range top burners
Probably have to replace the infinite switches. These are the controls you turn for the burners.
Posted on Nov 18, 2007
Fixe_You
  • 1800 Answers
SOURCE: kENMORE GAS STOVE MODEL 790-71105893
just the sears bring proper sears and replace them after u remove the old ones
and u need a ignition panel for the electric starter
rate me sir
if this not helping tell me and i will hep u further.
Posted on Aug 18, 2008
  • 415 Answers
SOURCE: Kenmore electric stove model c880.6383880
hi,
sounds like you have the old-style coil elements on you stove.
your problem is the switch under the element, called the infinite switch. i would suggest to have a technician replace it. they usually charge for the labour but if you have never done it before, it's money well spent.
Posted on Sep 13, 2008
SOURCE: gas stove /electric starter won't click to start cleaned stove
Try cleaning the starter with rubbing alcohol and toothbrush. There might be soap or boiled over residue on the starter. If that doesn't work, try using fine 150 grit sandpaper and gentle clean the starter with it. This problems drove me nuts too. Good luck!
Posted on Mar 21, 2009
Does white in one of the burners of an FES365ECA range happen from normal cooking?
Probably something boiled over. Realistically, an 11 year old range is fully depreciated in value and ready for replacement.
May 06, 2016 | Frigidaire Kitchen Ranges
The igniters for the 6 burner are not sparking. The igniter for the griddle does spark. i do small gas when trying to light-how do I get to the spark modules
Gas Stove Top Burners Not Lighting / Not Working - YouTube
? 5:20
https://www.youtube.com/watch?v=dP3l5AW3YrI
Jul 19, 2012 - Uploaded by Bill Newberry
... not lighting. These are the 3 main reasons for gas range burners to not light. ... I see the igniter sparking but not lights up the gas. One thing I ...
Gas Stove Ignitor and Burner Not Lighting - YouTube
? 1:10
https://www.youtube.com/watch?v=1ZXz8_Md8hI
Nov 20, 2011 - Uploaded by Mike Klimek
Here is an easy fix if you hear the ignitor "clicking" but not lighting the burner. For more information, go to ...
How to Troubleshoot Gas Stove Burner Ignition Problems ...
homeguides.sfgate.com > Landlords & Tenants > Landlord Problems
Dec 19, 2015 | Kitchen Ranges
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
Stove burners don't ignite
Try going to this website for a similar problem fix:
www.fixya.com/search/...capital_cooking...gcr305n_gas.../xl44_parts
Jan 10, 2013 | Capital Cooking Precision GCR305N Gas...
Replaced a burner and it won't come on
may have also burned the wires going to it turn off power or unplug then open up the top and look around , if you feel cofortable with hot wires and have a tester you could removed the wires from that burner isolate them so that they don't short out on the stove then turn on the power to that burner checking the wires for voltage should have 120 + or - a few is ok , if no powe r work back from there till you do find power
Dec 09, 2011 | Hotpoint RB757 Electric Kitchen Range
Where the burners plug into the range, they seem to be shorting out and burning the plastic parts.{this is in a rental unit} This has happened twice in the same unit , on two different stoves, with in four...
your tenant is probably removing the top burners to clean and everytime you take the burners out the terminal block they plug into gets alittle weaker connection.
you can replace the receptacles and then file or sand the burner terminals.
it is very common and also pretty easy to fix.
you just remove the old receptacle block and the cut the 2 wires, reconnect the new block and wiring and thats about it.
Jan 09, 2010 | GE JBP30 Electric Kitchen Range
Stove burner gets red hot
Since you do not have a thermostat control on your burners, I would suspect you may have an infinite switch (burner control), that controls that particular burner, possibly starting to go bad. The thermostat control is located on the infinite switch itself and may be cycling on and off improperly. Its hard to tell with intermittent problems, however. If in doubt, you can do a comparison between a working 8" inch burner and the one you are having problems with.
Another thing to consider with these coil type plug in burners, the receptacles under the cook top that they plug into can gradually become loose over time and cause the burners to arc. This may also cause excess current flow through the burner and will eventually cause burner coil damage and/or receptacle failure. I would troubleshoot this by, first, by unplugging the appliance and inspecting all the burner receptacles. If any show signs of burning or melting, replace them. You will need to lift the cook top to access them. Locate the screws under the bottom front edge of the cook top (open the oven door to see them) and remove them. With the screws removed, the cook top will lift up. Prop in place using the hinge supports.
NOTE: Remove the burner coils and bowls before lifting the cook top.
Replacements parts (including burner receptacles) can be purchased at pcappliancerepair.com, appliancepartspro.com, searspartsdirect.com, or repairclinic.com.
If you have any questions, please let me know. I hope this helps you.
Aug 02, 2009 | Kitchen Ranges
Non stop ignitor clicking
The thermostat tells the ignitor what to do. So, I believe the problem should be takrn up with the heat foreman
Jul 29, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Stoves Newhome ECH600MXa Electric Kitchen Range Logo
1,129 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
