To fix the water leak u can try doing the below method.
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Here is another solution:
inside of freezer, take back cover out and thaw the ice with hair dryer
or hot water. don't use any sharp tools. When thawed make sure water
drains through defrost drain.
Goodluck..
There are several causis from water leaking from the back of the fridge did you check is not condensation? In case you will need to lower fridge temperature
If your fridge has an ice maker, then check the water supply line.
If it was leaking refrigerant it would not leave water, maybe oil, but not water.
First you ensure is not condensing water coming out from inside the fridge. Then you pull your fridge out so that you can get behind it, then look for a small plastic tube coming out from the back .this is the condensate drain tube, it runs down the back and under the fridg to a pan. where the heat from the motor will evaporate the liquid that collects there.make sure the tube is not disconnected, if it is not then check under the fridge and see if the pan is full of water , dirt.or leaking. some pans can be accessed from the front.while you have the fridge out it,s a good time to pull the plug and brush and vac in and around the motor. be surprised Howe much dust collects there. also while you at it disconnect the tube and blow it out to make sure it,s not plugged.
regards
I doesn't seem to be condensation. I happens every few days and all the water appears in 5 mins. The last time it happened, 1 hour ago, I unscrewed the back cover. The coil had water dripping off it. I looked inside a few minutes ago and the coil is "frosted" up. I still think it's like a defrost cycle, but I don't know that much about refridgerators.
