Question about Whirlpool GBS277PDS Electric Single Oven
Oven elements will not heat
We had a power outage, when this occurred the oven was in cleaning mode.
When the power was restored, i reset the clock/timer and then found that neither of the elements would heat for bake or broil.
The clock, lights and fan in the oven are all working but will not heat.
Is there a fuse too look for or is there a fix I am not aware of?
  • 3 more comments
  • kf6wax Feb 24, 2008
    Thanks Wiz!!
    That was fast!!
    Is it easy to fix or does it require a tech to come out and fix it??
    TIA
    kf6wax
    if i hold the cancel button I get this error code,
    EO -FO-
    might that help??
    kf6wax
    The actual model number is GBS277PDB11 and was purchased in Lowes a couple of years ago.
    Will that make any difference?
    Thanks again for the swift and truly excellent response, The actual Model is GBS277PDB11 sighted better with the door off! This was purchased at Lowes about 3 years ago
    Does that make a difference to the part number??
    Thanks again
    kf6wax aka steve
  • Anonymous May 03, 2008
    After cleaning the oven. The heat element will not work.
Just a follow up report on aborcass's solution to the oven problem.
Just took delivery of the suggested part, removed old thermister and installed new part, back to the breaker and apply some juice to the circuit.
Turned on oven....BINGO!!!!!
Oven now is as hot as the wife would like it!!
Well done and well earned FixYa (already awarded)!!
Many thanks again
Steve, aka kf6wax
Posted on Feb 27, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
Theres a thermostat on the back wall that problaby blew out as a result of surge,its wired in line with both bake andbroil element
Posted on Feb 24, 2008
  • Ron Coons
    Ron Coons Feb 24, 2008
    you would need to remove the wall oven form the wall to repair it, a buncha screws but not terrible difficult . partnumber for that particluar themo,( assuming your model number of oven is gbs277pds) is 4451442 retails for $40 or so
  • Ron Coons
    Ron Coons Feb 25, 2008
    nope that wont change the number,your good!good luck
Why doesn't oven work after using the self- cleaning mode?
Check for incoming power; you may need to change the heater element.
Sep 11, 2015 | Whirlpool GBS307PD Electric Single Oven
How do I restart my stove after a F9E0 code flashes?
The control thinks thinks the heating circuit is open was the oven in use when power went out possible one of the leads may have come off or burned off one of the elements I have seen outages damage a lot of controls with oven off try cancel/off, cancel/off then start to go into diagnostic press the 3 or ^ key till you get to errors follow the prompt to reset this my help
Apr 03, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool built in electric oven
The upper element is for broiling and should not come on until you tell it broil. If it is coming on as soon as you turn on the breaker then it sounds like the printed circuit control board is bad. There is a relay on the board that engages when you program in the broiler. The relay can be hard to find and may not be removable. My broiler would come on when I programmed in the bake mode, go into runaway heat, put up a F10 code, and shut off. I could not clear it until I programmed in the clean mode for 2 hours. Now it works great.
Sep 07, 2014 | Whirlpool RBS275PD Electric Single Oven
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
Jan 20, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 | Ovens
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
No heat from any element on any setting
first check your voltage to the unit
Dec 30, 2008 | Ovens
Oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Dec 14, 2008 | Ovens
Power outage Blodgett Conveyor Oven
On the back of the motors there are safty overload reset's, these are small red push in buttons. Also there are fuses for each motor inside the control panels assembly.
Jun 02, 2008 | Blodgett Ovens
Whirlpool GBS277PDS Electric Single Oven Logo
330 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
