Question about Soltek SL-KT600-RL Motherboard
Upgrade limitations Hi! I am just trying to upgrade a SL-75drv4 P2 (i.e. PCB version 2) motherboard based system. Can this motherboard support a Thoroughbred type Athlon XP processor, or I should stay in Palomino's world?
Yes you should
Posted on Feb 24, 2008
Can I upgrade my PC with existing A7V8X-MX motherboard with higher processor, Presently I have AMD Atholon XP 2000+
It also supports Socket A for AMD Athlon™XP up to 3200+ processor
Thoroughbred/Barton core support
Nov 17, 2010 | ASUS A7V8X-MX (90-M7A780-G0EAY)...
Want to upgrade to amd athlon 2
Hi........Socket 939 is an outdated processor and not compatible with Athlon 2. You may find a 939 dual core on ebay, but suggest you save up for an AM3 mobo. Hank
May 10, 2010 | ASUS A8N-E Motherboard
Are any of these processors fast and which one is faster
I think I helped you yesterday and we came up with a solution that Athlon XP 2200+ is faster than 1350+.
Jan 03, 2010 | EPoX EP-8KRA2+ Motherboard
Amd athlon xp 2200+???????????????
Your EPoX board should support AMD Athlon 2200+ Socket A processor.
Jan 01, 2010 | EPoX EP-8KRA2+ Motherboard
Memory upgarade
Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
Jul 21, 2009 | ASUS A7V400-MX Motherboard
Motherboard cpu
The motherboard you listed supports AMD processors, (AMD Athlon XP/ Thoroughbred/Barton)not Pentium.
Jul 13, 2009 | ASUS A7V400-MX Motherboard
A7V266E/AA MB CPU
The Ol' Asus A7V266-E?
1.The fastest Front Side Bus setting is 266MHz
2.Uses Socket 462 AMD processors
3.Uses Athlon, Athlon XP, and Duron AMD processors.
I would stick with an AMD Athlon XP. Fastest one? Hmmm, I believe that would be the AMD Athlon XP 2600+
The one that operates at 2133MHz with a FSB of 266MHz. Part number AXDA2600DKV3C
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors#Athlon_XP_.22Thoroughbred_A.2FB.22_.28Model_8.2C_130_nm.29
Here is the Motherboard Manual for your Asus A7V266-E, (It's a PDF file download. Let it download all the way before looking through it)
http://www.motherboards.org/files/manuals/1/a7v266e-100.pdf
If the above direct link does not work for you, then go here,
http://www.motherboards.org/mobot/manuals/ASUS/A7V266-E/ (Click on -> Download <- all the way to the right of -> File:a7v266e-100.pdfVersion:--Release Date:--)
Go to Page 19, Item 2. NO POWER connected to computer, make sure the SYSCLK (System Clock) DIP switches are set to 133MHz.
1, 2, 3, and 4 are set to the OFF position for 133MHz.
All you will see is the ON. The switches go to the opposite side as shown in Item 2.
I'm sure they are set there however, as your 1900+ you have in right now, uses a 266MHz FSB.
I should explain.
AMD processors are Double-Pumped. Therefore the 133MHz setting will become 266MHz for the processor. (Intel processors are Quad-Pumped.
They are both the same Core, (Thoroughbred A/B, Model 8, 130nm), so a BIOS update shouldn't be necessary.
Jul 07, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
Apr 03, 2008 | AMD Duron , 750 MHz Processor
Upgrade
Thank you for the information. Please find the CPUs supported by the Motherboard of your computer below.
Duron: 1.6 - 1.8 GHz at FSB 266 MHz
Athlon XP:
Palomi** Core: 1500+ - 2100+ at FSB 266 MHz
Thoroughbred Core: 1700+ - 2700+ at FSB 266/333 MHz
Barton Core: 2500+ - 3200+ at FSB 333 MHz
2500+ - 3200+ at FSB 400 MHz
Sempron: 3000 + and up
I see that the present processor is requires ** upgrade as it is one of the best match availble for this motherboard. However, you can upgrade the Memory to 2 GB using two 1GB
DDR 266/333/400 modules to improve the system perform performance. Also, you can consider for a video card upgrade. Your computer supports both AGP and PCI video cards.
Also, you can download the maunal for the motherboard of your computer from the link below for your referance.
http://www.elhvb.com/mboards/oem/emachines/manuals/K7MNF-64_manual.zip
Regards
Mar 07, 2008 | Computers & Internet
SL-75DRV5-C Soltek motherboard
Are you saying that another processor is recognised (so board is OK) and that this processor is recognised in another board (so CPU is OK)or are you saying that it is recognised as something else? Have you updated the BIOS? Have you checked the switch settings? SW2 (front of case)should only have DIP6 on; SW1 (back)should either have DIP5 off for autodetect, or DIP1 off for 11.5 multiplier (I think!).
Sep 25, 2007 | Computers & Internet
Soltek SL-KT600-RL Motherboard Logo
102 people viewed this question
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
Paul Bade
Iqbal Husain
Iqbal Husain
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
