Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Water leakage in and below freezer on Maytag MFD2560HES
Every week or two a puddle forms below the lower left hand side of the freezer.
Ice builds up inside the freezer bottom ans has to be removed or it eventually reaches the basket and the door cannot be open.
    President:
  • Maytag Master
  • 2,651 Answers
You have a clogged defrost drain, or your ice maker (if so equipped is leaking. clogged drain can be remedied removeig drawer , andmelting ice build up behind rear panel of refrig, you see an aluminum trough that the water drips down,using a hair dryer melt all thatice out of the way to clear the drain tube(i use a steam machine i purchased from infomercial works extremly well
Posted on Feb 24, 2008
I( find a puddle of water on floor at front left hand corner on freezer side..I took the freezer drawer out and found ice build up under it ,could this cause my problem.. this happened about every 24 hours...
The problem with your refrigertor is that the defrost drain is plugged up. After you get the ice buildup out of the freezer section you will have to locate the drain system. It is in the back of the freezer at the very bottom.It needs to be cleaned out. Hope this at least leads you in the right direction.
May 27, 2011 | Maytag MSD2756G Side by Side Refrigerator
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
MZD2766 GE - A puddle of ice forms at the bottom of the freezer
Sounds like the defrost drain is cloged. There is a hole at the bottom of the freezer behind the back wall. if this is cloged then the water that is suppost to drain there will overflow and freez.
Jul 04, 2010 | Maytag MZD2766GES Side by Side...
About 1/4 inch of ice forming in bottom of freezer about every 3 weeks. small puddles of water form under the front of frig when this freezes
That is a typical defrost drain blockage symptom unless the icemaker is over flowing, I will return with a link and more information. Sea Breeze
Jan 18, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Where is the drain located?
Hi, The drain is located behind the rear inside freezer panel. Remove the panel and find the drain hole under the evaporator coils.
I hope this helps you.
Vic
Jul 02, 2009 | Maytag MSD2732GR Side by Side Refrigerator
I have a puddle forming on the freezer side of the maytag msd2756gew side by side refrigerator. It seems i have a leak. what could be leaking and how do i fix it?
Your Ice Maker could be leaking or the defrost drain behind the back freezer wall could be blocked with ice or another source of blockage leading down to the pan below your refrigerator where the water is heated by the evaporator fan and replaced back into the air inside your home. You will need to unplug the power before going into the back of your freezer. Let me know if you would like help. Sea Breeze
Jun 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
ICE BUILD UP ON THE BOTTOM OF MY FREEZER BELOW THE LAST TRAY
clear ice and with hot water pour into the drain hole till open and drains ,, take back panel of freezer out and wrap a piece of thick cooper wire around the heater and drop into the drain hold about 1in and it will keep drain open / thanks
Jan 14, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
697 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
