CPU upgrade Hi, my name is Tom. I installed the following cpu onto an ASUS P4B-LA motherboard . The result was no OS (XPsp2 Home Version). the hardware came on ,fans ,cd, dvd. Also the computer would shut off instantly with just atouch of the power switch. I then reinstalled the original cpuand that worked . That's how I was able to find you . HP is no help as they only list 1 bios UG which i already have . Any help would be great. Thanks Tom sSpec Number: CPU Speed: PCG: Bus Speed: Bus/Core Ratio: L2 Cache Size: L2 Cache Speed: SL7EY 2.80 GHz 400 MHz 28 512 KB 2.8 GHz Package Type: Manufacturing Technology: Core Stepping: CPUID String: Thermal Design Power: Thermal Specification: VID Voltage Range: 478 pin 0.13 micron D1 0F29h 68.4W 75°C 1.475V-1.55V1
  • Knowsalittle Feb 24, 2008
    Dear SDZAKKMF,
    Yes, they are both intel and 478 pin.
    Thank you for responding
  • Sean  Cheren
    Sean Cheren May 11, 2010
    were they both amd or both intel. if the first was intel and you used amd, that issue would occur. also check the socket type to make sure it is in fact 478
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Go to the Intel website--they are pretty good at telling you which CPUs are compatible with each of their motherboards.
Posted on Feb 24, 2008
Prosessor cash in compadible
Hello the cpu list is here:
The following table shows the supported CPUs for this motherboard
http://support.asus.com/cpusupport/list.aspx?SLanguage=en&p=1&s=15&m=P4B533-VM&os=&hashedid=n/a
It only supports dual core cpu.And only the listed.
You maybe have to upgrade the bios to support a bigger cpu.
Good luck
Nov 24, 2012 | ASUS P4B533-VM Motherboard
CPU compatibility issues
the cpu test is something a computer does to test the board. it sounds like there is something wronge with it. pentium 4 boards very with the clock speed. it depends on the age and if it can handle. if you went from a 1.7 to a 3.2 than you might be overloading it not allowing the computer to register.
basiclly what you need to do is get you a board that is already set-up for a 3.0ghz or higher proseccor.
even through it is a p4b some of the older models can only be upgraded to a 2.0ghz.
Aug 12, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
P4B-M standby LED lighted and CPU fan jerked a little and stopped when power is plugged into the power supply unit. The motherboard does not seem to power up/ CPU fan remain still even the power switch on...
This is an issue with the power supply (SMPS) in your computer... Replace the SMPS will fix the issue...
It is not adviced to service the SMPS, because servicing the SMPS will not give proper power supply to the board, which may result in damage of Motherboard...
Dec 15, 2010 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Can I use Pentium 4, frequency 3.0 GHz with Asus P4B?
Asus support says the fastest CPU you can use in that MB is a P4 2.6 GHz or a Celeron 2.8 GHz.
For the P4 you need BIOS ver. 1011 and for the Celeron you need ver. 1013.004.
Here is a link to the entire list:
P4B CPU Support
Thanks for using Fixya.
Apr 14, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Can I use Pentium 3 GHz with Asus P4B?
no, you cannot, cpu socket on pentium3 is not the same, as pentium4
I want sound driver and vga driver of my laptop z755110 if u have zenith drivers so plz call me.9250327275 MY NAME:RAHUL LUTHRA PLACE:DELHI,LAXMI NAGAR
WHAT TYPE OF CPU SY-61WM/L SUPORT AND SPEED RANGE?
THE TYPE OF CHIPSET?
THE TYPE OF BIOS VERSION?
MOTHERBOARD FORMFACTOR?
MOTHERBOARD DIMENSION?
Jan 28, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Asus P4B 1.7 mhz P4 motherboard restarts every 10-15 minutes...
Check the CPU temprature from the BIOS. Sometimes if the CPU overheats the system will automatically reboot. High CPU tempratures goes form (60-70). You can also monitor the fan speed and cpu temprature using this utility
http://www.almico.com/speedfan.php
Oct 27, 2008 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
ASUS P4B motherboard problems
I had the same problem a couple of times,have you tried another CPU as this points to the fact that the processor is faulting.
Jun 27, 2007 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Computers & Internet Logo
204 people viewed this question
David Payne
David Payne
