Question about Dryers
Problem with Indesit tumble dryer
The water container "full" light on my Indesit IS70C tumble dryer is staying on even though the water container is empty. Consequently, the dryer is not heating. I have thoroughly cleaned the filter and condenser. Any suggestions?
ANNE
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Posted on Jan 10, 2010
Make a lot of nosie
Hi mervyn2011
Sounds like you have a bearing problem or drum roller/slide problems.
You will need to take the dryer apart to determine which problem it is.
For an owners manual go to the following webpage
Please take time to rate me
Bud
http://www.indesit.co.uk/indesit/_pdf/manuals/19504260005_UK.pdf
For parts go to the following webpage.
http://www.ransomspares.co.uk/parts/brands/indesit/tumble-dryers/is70c/
Oct 16, 2012 | Indesit IS70C Electric Dryer
The light on the water drawer of my IS70C dryer is staying on and the dryer isnt drying.
Thank you for the direct question but unfortunately we don't work on Indesit units and have no documentation on them, so I am unable to help you.
Sep 03, 2011 | Indesit IS70C Electric Dryer
I have Indesit IS70C dryer and all of a sudden it's not getting hot when switched on and the water container is empty..water is not draining from the clothes to the container and machine is not getting...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.//.';';]\\
Jul 25, 2011 | Indesit IS70C Electric Dryer
Indesit condensor tumble dryer does not heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 08, 2011 | Indesit IS70C Electric Dryer
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
Hi,my indesit IS70C tumble drier works but does not heat up.\possible causes please.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Indesit IS70C Electric Dryer
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Indesit Dryers
How can i fix my indesit is70c tumble dryer? my indesit is70c tumble dryer wont heat up during performance
open the back panel , not the the full back just the smaller panel located near the bottom half.
the termo will be screwed onto this panel . unscrew and you will see two circles near the top one will have a small pin hole in it . stick a pin in till you hear a click replace and should work fine
Mar 05, 2010 | Dryers
Indesit condenser tumble dryer water light always on even though container empty
Maybe trapped water in the dryer. Switch off and remove power from wall. Remove condenser unit from the dryer (clean the condenser while you have the chance with plenty of water and an old toothbrush - it will probably be filthy). With the condenser unit removed stick an old tea towel in the hole where the condenser was and then tip the dryer on its side. If there is water it will either run onto the tea towel or onto your kitchen floor OR into the water container!
It worked for me, honest...
Oct 06, 2008 | Dryers
My indesit is70c tumble dryer isnt working correctly. The light which tells you to empty the water is staying on the water draw isn't filling up with water and it does not get any heat. ( I Know I Am Blond...
problem is probably the pump that sends water up to the container. take small panel off back and pump and water container is exposed. power the pump independently and see if it works
Aug 05, 2008 | Dryers
Dryers Logo
1,005 people viewed this question
Top Dryers Experts
Marvin
Marvin
