Question about Kenmore Elite 45986 Front Load Washer
Slow filling of elite h3t
First burst is fine, but cold and/or hor/warm filling is slow, with background buzzing
If solenoids or screens were problem, I would not get the first burst in the ordinary programmed 3-4 seconds, prior to the control moving it to the specified wash cycle
  • 156 Answers
If you put new stanliss hoses with the flood control in hoses change your hoses fix your problema
Posted on Feb 28, 2008
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
Cold water slow to fill
It buzzes because 120 volt AC is within the hearing range and means electricity is trying to open the solenoid plunger.Make sure the faucet the hose is connected to is turned on. swap hot and cold hoses and see if the Hot water is now a trickle. The solenoid asm that the hoses connect to can be removed and dissambled. It's a no brainer. the parts are mirrors of each otherBe sure to unplug the washer first. Remove the hoses at the solenoid assembely the valve asm has wires coming to it that just push on. A loose connector MIGHT cause this problem. Draw a picture of the wire connections, noting the color of each connection.Now the fill solenoid asm can be removed. It's probably held to the cabinet with one screw. now there are some screws holding the coils to the plungers. disassemble the valve and clean it up. Don't lose the springs that push the plunger to the closed position. At this point you could even swap the plungers on the asm. Just clean the obvious lime and **** upp using a tooth brush and water.DON'T LOSE THE SPRINGS,DON'T EVEN WASH THEM. Assembly is just should not have to buy any parts, but don't lose the springs.
Nov 30, 2011 | Admiral AW22 Top Load Washer
On our Model LAT9635AAE washing machine when cycle is on cold/cold the water fills at a very slow flow. If (while water flowing on cold) the water temp switch is switched to warm and back to cold the cold...
You have a bad fill (mix) solenoid valve. The valve in the solenoid is hanging up and by switching it back and fourth between hot and cold its just working its way to the proper position..You were on the right track.....
Sep 16, 2010 | Maytag Washing Machines
Washing machine slow to fill
yes or a water pressure issue, mosty when using hot or warm
May 19, 2010 | Fisher and Paykel Active Smart E522B...
Buzzing sound
does it ever give an error code? a common problem on whirlpool made machines is the dispenser arm getting caught when changing positions. This part is in rear of detergent dispenser housing and uses a motor and a arm to select detergent/ softner/ bleach/ and fill. you can remove top (screws on back) to watch this.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
No cold water, only hot
The cold water inlet line is either clogged (it has a filter screen in it) or the cold-water solenoid valve is malfunctioning.
Remove cold water line, check for obstruction -- if no success, inspect electrical connections on solenoid valve (where the cold water line attaches to the back of the machine). If valve is getting current, take it apart and clean it. If that doesn't work, replace the solenoid valve.
May 29, 2009 | Washing Machines
Slow rinse cycle fill
take the hose off the cold water valve and check the screen on the water valve ,make sure the cold water is on all the way and the hoses are on the right valves get a water bucket hold the cold water line in it open the cold water valve to check the pressure
Jan 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Amana washer has no hot water - cold works fine
There is a solenoid control valve on all washing machines, located where the water hoses enter the machine. If you have a rubber mallet, you can whack the machine gently with the mallet. If the problem is resolved, it was just a stuck valve. If not, then you likely will need to replace the whole solenoid valve control. Typically there are controls for each water supply.
Dec 04, 2007 | Amana ALW880WH Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
73 people viewed this question
Sal De
 Brian Main
Brian Main
