Question about Zyxel P660HW-D1 Router
Zyxel P660HW with vista issues
Hi there
i cannot seem to be able to get Vista to connect to my zyxel modem through the IP address, i have plugged the same modem into my laptop running XP and it instantly works, with vista all i get is Internet Explorer saying that it cannot connect
  • zaphod30 Feb 24, 2008
    thank you
    i will have a go at that, i have already disabled the firewall and tried the "switch everything off and count to 10" method, and the both appeared to do nothing.
    i was going to try running IP config and make sure the PC could see it, do you think that would be an option?
    where do i change the network settings in Vista?
  • 19,396 Answers
If you are connecting via usb you will need to install all software and drivers on your pc before plugging modem in. If you did install them already you may need to reinstall
If you connect through ethernet (RJ45 terminated network cable), you may have a firewall preventing regular acess to network.
solutions
1) restart pc and modem it may work just with this
2)USB only: reinstall all modem software, then restart all.
3)Ethernet only (network cable), |Restart all and disable firewall. If this does not work you may need to change network settings on your computer (fo example change IP from static to dynamic).
regards
Posted on Feb 24, 2008
No internet when adding switch between modem and router
The router controls and assigns IPs. Configuration goes from ISP modem to router to switch.
Mar 20, 2013 | Zyxel Communications Zyxel GS105B Desktop...
Cable Network Routing with Zyxel 600
You have to set different ip address. To clear this up this how I got my setup. I have verizon internet. I use a westell 6100g modem, I have the local ip address set for 192.168.1.1 and I got a linksys wireless router and the ip address set for 192.168.9.1. Then I plug my modem into the wan port and it works. What am I doing is setting a static ip address from my modem to the router and using the router to distribute my address through the network. If you have any printers on the network you need to change that numter to 192.168.9.x number. If you don't have two different numbers set the router will take over.
Aug 09, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
Advance options are hidden in the modem control panel
log into the wrouter ip address.
check the mfg website for the exact address
Jan 15, 2009 | Zyxel P660HW-D1 Router
How do you access WPA Key Settings on a ZyXEL modem?
To access Zyxel configuration/setup utility, launch a web browser (Internet Explorer, Opera, Firefox, or Netscape, etc.) on your computer, type in http://192.168.1.1 (default IP address for most Zyxel wireless devices) in your Internet browser's Location/Address bar, and then press Enter on your keyboard.
If presented with a user authentication (login) screen, try the following:
Default Username - Zyxel Wireless Router: N/A (none, leave blank)
Default Password - Zyxel Wireless Router : 1234
If you cannot login using the above, verify that (a) you are entering your password correctly, and that (b) your CAPSLOCK key is off. It could also be due to the firmware (a set of instructions stored on an EEPROM microchip) on your Zyxel product being corrupt. If so, you would need to reset your Zyxel WiFi router to its factory default settings.
IMPORTANT: Do not forget to promptly secure your Zyxel router (using a strong password, a non-obvious WEP Key, etc.) following a reset to factory default settings. Failing to do so may potentially expose your entire WLAN to scammers.
*Your vote is highly appreciated. Thanks in advance.
Dec 27, 2008 | Zyxel P660HW-D1 Router
Zyxel p660hw wireless problem
I forgot my modem wireless password...and I can not make a connection without cable...
Jul 12, 2008 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 drivers
Since you are referring to a router you can access the configuration using the web configuration you just need to type the router default ip address on your browser to access the configuration.
the default ip address is 192.168.1.1
http://www.zyxel.com/web/product_family_detail.php?PC1indexflag=20040812093058&CategoryGroupNo=AC5783AE-9475-41AD-BDA5-0997187F44AA
http://dl01.zyxel.com/DownloadLibary_ShortName/P-660HW-D1/quick_start_guide/P-660HW-D1_1.pdf
Mar 02, 2008 | Zyxel P660HW-D1 Router
Zyxel P660HW - Wireless Router adsl modem set up poblem
Check in network settings that the two computers have not the same IP address.
Feb 13, 2008 | Computers & Internet
ZyXEL adsl wirless modem router P660HW
To bring up the blue screen you need to open internet explorer (or whatever) and type the ip address given. In my book it says 192.168.1.1 after that you should get the blue screen. You can set up the connection then.
Jan 08, 2008 | Zyxel P660HW-D1 Router
Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Jan 01, 2008 | Zyxel P660HW-D1 Router
Zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Nov 22, 2007 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Logo
406 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
