Question about RCA P46921 46" Rear Projection Television
High pitched squeal
I have an intermittent high pitch squeal coming from the back of the TV. I can change the pitch by manipulating the area where the cable enters the back of the TV. It's not the cable, it the part of the TV where the cable and A/V cables attach. It is very loud and getting worse. TV is around 7 years old. Plan on upgrading to LCD, but would still like to keep this for the basement.
Thanks
    Novelist:
    Scholar:
  • 96 Answers
What an RCA I hope you didn't pay mutch for this, NO it's not the part of the board were the cable goes in, the so call squeal is the horizontal oscilation of the coil you hear, narmaly it is at the rate of 15747 hz, to find your problem you most open the back cover, and while the ptv is on try to hear by insolating the noise were it is comming from with a credit car or something that will hide the section you trying to find, it will be a transformer or a coil, close to the power supply or the horizontal defflection section. To fix your problem well that's all a different game, you must contact me via e mail at rlandry@vianet.ca
I hope this help.
Meanwhile keep on smilling, life to short
What about Bob
Bob
Timmins, Ontario
Posted on Feb 24, 2008
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
I have a Toshiba 27AF42 and I get a high pitched squeal after the TV has been on for a few minutes. Any ideas how to fix this? Once I turn the TV and back on again the squeal goes away.
yes. its the horizontal linearity coil resonating. take off back. and while unit is on, take a plastic straw and push on coils in the high voltage area. you will find one that squeals when pushed on, or will stop squealing when pushed on. solder that coil and area. that will fix 80 percent of the time. if you push on it and the squeal tone changes, solder it and silicone it done. fixed.
Nov 14, 2009 | Toshiba 27AF42 27" TV
1994 nissan pickup high pitch squeal when driving
it could be the engine belt or the brakes are bad listen to where it coming from and you will know which you have to change
Aug 18, 2009 | 1994 Nissan Pickup
High pitched squeal
Hi...
Does the squeal come from the TV cabinet or the speaker?
If from the cabinet , it's most likely the Horizontal high-voltage section of the set.
Find someone that's good with hand tools,unplug the set from the wall outlet, let it sit for a good 30 minutes.
have someone open up the back of the set and dust out and vacuum out any dust from inside the set.
Put back together and try it out.
Jan 01, 2009 | Samsung TXN2034F 20" TV
NO PIC HIGH PITCH SQUEAL COMING FORM BACK BOTTEM PART OF TV?
Squealing sound means you have something shorted in high voltage area around FBT on Power/deflection board.UED has replacement boards & Misc Parts for these sets if in stock call them1- 800-648-6657
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
My set has deveolped an intermittent high pitch squeal.
It always nice when the high-voltage circuit gives you fair warning of impending doom. Have the high-voltage (flyback) transformer replaced now before it fails catastrophically and wipes out other stuff with it. There are other things that could make noise too, same advice applies to them.
Hope ya fix it!
Jan 03, 2008 | Toshiba 36AF43 36" TV
High Pitch Sounds
In this model the horizontal drive coil vibrates and makes a high pitch squeal. Most times it is intermitent. Touching on the coil with something (non electrical, like wood) will make it stop or change it's pitch. The fix my shop uses: It's not to technical, but, we put fingernail polish around the coil. It's a remedy I've used for decades and has always worked. Some shops use a hot glue gun. With the back open you can hear the coil to locate it. When fixing the problem have the set unplugged. When a technician is working on a television while it's plugged in. He uses only one hand and stays away from the high voltage.
Jun 25, 2007 | RCA HD52W59 HDTV Projection Television
RCA P46921 46" Rear Projection Television Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
