Question about Proscan PS52800 52" Rear Projection Television
Proscan PS 50670
11 years old Tv
Problem is: too often, I loose image and sound, lot of horizontal lines.
I have to shake cable at the back or knock hardly the side to recover both image and sound.... till the next time few minutes later!
Is it a cold soldering problem or anything else? Expensive to repair?
Thanks for your help!
ROBERT robert88@videotron.ca
  • Proscan Master
  • 8,617 Answers
Try soldering the tuner connections RCA/proscan have had some issuse with the solder around the tuner.
Posted on Feb 24, 2008
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Distorted picture on my 32" Proscan TV...(about 15 years old)
The RCA GE sets have a problem with bad solder connections in the tuner unit which also causes numerous symptoms including poor regulation, no vertical deflection, low audio or dead set.
Pulling in from the sides is either poor regulation or a bad eeprom/solder join issue
Mar 13, 2009 | Proscan PS36123 TV
Ps 27123 have sound, tuning etc only small horizontal color band
Hello bdedrick708,
If what you are trying to say is that you have a 1/4 inch horizontal line across your screen, this means that something in your vertical deflection circuit has failed. This could be the vertical oscillator, the vertical output processor, the vertical coupling capacitor, or the vertical section of the yoke transformer.
If what you are talking about is a vertical line from top to bottom then you are possibly talking about a failed horizontal section of the yoke transformer.
Why so little about the horizontal section of the yoke? That is because if the horizontal section fails completely then you would lose high voltage and no line would be present because you would not have raster (screen light).
In any even check the yoke transformer first. Then work back from there.
I hope this helps,
Thank you,
Shuttle83
llc.com/">http://www.electron-age-technologies-llc.com
Feb 07, 2009 | Proscan PS27123 TV
Proscan PS27123 TV Problem
just to be sure, is it vertical or horizontal? Anyway, if it is vertical, it could point out to the vertical Ic section or some loose contacts along the lines. If it is horizontal, it could be a filter capacitor along the horizontal Circuitry. Mark the high voltage capacitors along the high voltage sections.
regards,
chris
Jul 23, 2008 | Proscan PS27123 TV
Vertical line picture
problem is caused by the loss of horizontal deflection signal. It is quite surprising that the entire unit is still working, since usually, a loss of H-Out will disable the entire set. Problem can be as simple as loose solder connection to a more complicated defective horizontal circuit. I would suggest havint it checked by a professional TV tech.
Jul 16, 2008 | Proscan PS36500 36" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
JVC model AV 278p6 standard television
I'll bet you have vertical output IC with some pins not soldered. This IC ( integrated circuit) is a "chip" that makes the picture fill out from top to bottom. After a period of time heat will cause the pins to crack loose on the circuit board. You need to have a tech check it for you. Stargazer
Aug 16, 2007 | JVC AV-27530 27" TV
Proscan PS52800 52" Rear Projection Television Logo
87 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
