Same problem, but green light and red light flashes. Lens goes in and out, but no picture on monitor.Same problem, but green light and red light flashes. Lens goes in and out, but no picture on monitor.
You can't post conmments that contain an email address.
You have one of two problems. 1st is a bad battery that is not holding a charge. or a bad lens. I repair these issues all the time. Email is [email protected]
Make and model please
Does it not turn all at all?
Does it turn on but not display maps?
Does it display but not track or give directions?
Please describe the problem in more detail.
hi im josh in cebu phils. may i help you friend? to turn on your web cam. first you need to plug in the usb connector cable built in your cam and also the mic.plug to the pink slot for mic. and usb for usb socket at the back or in front of your pc if available then you install the cd driver built with your cam.you install the driver completely then you reboot your pc.after rebooting you will see the icon zoom and cam in the desktop, you may click then bang! Problem solved. good luck friend. please vote me so that i will know if i helped you so.
Ok im not sure what cam you have or comp that your using, but cahances are you need to go to your web cam settings:START/ALL PROGRAMS/ "your cam"/ CAM SETTING. there you should see inverted or mirror settings, it might even be in ADVANCED SETTINGS try and look for it, Good luck JLS
P.S. you could always turn your cam upside down! LOL Just kidding!
