Question about Zenith R56W36 56" Rear Projection Television
Picture problems.. ok..it seems as though my problem could be easily solved. for some reason i pushed a button that made the picture only fill part of the screen. now the picture isn't filling the hole screen and i want it to. what do i do. thank you.
    Problem Solver:
I have the same problem and I can tell you that you have to replace the convergence board. Iam in the process of ordering the board and putting it in. I can email you and let you know how it goes
Posted on Feb 29, 2008
Machine fills wont agitate or spin but will drain. Think the safety switch is problem. Need pictures or video of how to fix it.
the safety switch turns everything off and as you have filling and draining , I would be looking else where
The problem may be in the control panel
check that all the buttons are either fully in or out as any 2 buttons set wrong ( partially pushed ) will cause this problem
If ok get a repair person to check it out.
Apr 09, 2015 | Washing Machines
I have aquarius+ wf740..... when I switch machine on the wash enhance is flashing and power on/off is solid. Once I click any button the wash enhance stops flashing However the buttons do nothing on off...
Thank you for providing detail in your question and typing in coherent sentences, you are the first person today!
As you have checked basically everything the best option is to get a quote for a fixed price repair. You may well have a faulty control module, these are expensive to replace and require specialist tools to program the replacement.
Aug 03, 2014 | Washing Machines
Sony BDP-S350 - no video..only audio on all outputs
This is button config for master reset without picture:
Home Left button x 3 Down button x 7 ok (centre button) ok Down button x 6 ok Left button x 1 ok ok wait a couple of seconds for settings to complete, when you switch back on you should have a picture and be back at language set up screen.
Hope this helps.
May 30, 2009 | Sony BDP-S350 Blu-Ray Player
Photo tray problem C5180 push output tray all the way down
I had the problem today and searched everywhere and only found the question posted about five different places but no answers. I'm obviously not the only person who has had this problem. HP's website offered no advice.
I spent some time with HP's "live chat" feature. Obviously not live, but fixed the problem.
Here's the discussion that solved my problem:
Von : Without turning the product off, remove the power cord from the back of the product.
Wait 30 seconds and then plug the power cord into the back of the product.
If the product is not already on, use the On button to turn it on.
Lance Goodthrust : did that
Lance Goodthrust : came back on and had the same error message
Von : Okay.
Von : Lets perform the steps.Von : Use the On button to turn on the product.
Remove the power cord from the product.
Press and hold the # and 6 buttons.
While holding the buttons down, connect the power cord to the product.
Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
Use the On button to turn on the product. The reset information appears on the color graphics display.
Lance Goodthrust : okay, give me a few
Lance Goodthrust : printer is in other room
Von : Okay.
Lance Goodthrust : That seems to have solved the problem.
Lance Goodthrust : Thanks.
Von : Okay. Its alright.
Apr 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
No picture on monitor 997M
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 08, 2009 | Microtech Computers & Internet
Sudden loss of picture, sound comes though ok
It sounds like the exact same problem that my son recently created. The only solution I've determined is to reset the player to it's default settings. Although it took a little while (since the video display was not present), I finally found the right combination of buttons to push on the remote and now the problem is fixed. Insert a disk, then push the following buttons: Stop, Stop, System/Menu, >, >, >, v, v, v, v, v, >, OK
After the above sequence of buttons, the main player screen should reappear on the tv.
Croce23
Jan 04, 2009 | Philips DVD727 DVD Player
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Oct 07, 2007 | Hitachi 35UX80B 35" TV
Emerson tv model no. ewf2704
Hi: When you say small horizontal screen, ¿Do you mean picture does not fill the screen completely from top to button? ¿Do images display normally though they are smaller in size? ¿Is color and definition of signal OK? Please answer so I can have a better picture of the problem.
Sep 19, 2007 | Emerson EWF2704 TV
Blurry Image
I had that problem too. So I pushed the MENU button and got to looking to see what all was there. I moved down to where it says SCENE and clicked on it. I moved it down to portrait. On my camera that fixed my problem of no flash and it seemed to take forever to take the picture. You could try that. But I did notice though, that when I turn my camera off and then back on I have to re-do it.
Sep 10, 2007 | Vivitar ViviCam 5100 Digital Camera
Zenith R56W36 56" Rear Projection Television Logo
42 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
