Question about InFocus LP 600 Multimedia Projector
Internal mirror broken
I have an LP600, and the internal mirror is broken. It is a small 4-sided box that is made of mirrors, behind the color wheel. It was cutting off half of the image on the screen, so I took it apart and found that this little rectangular box had one side out of whack. Upon looking at it further, I found that the glue had just broken and not the mirror itself. Is there a way to fix this, or does someone know where I can get just this part? I didn't pay for the projector, it was free from my work, and I can have it. I just want to get the part or a way to fix it so that I don't have to pay an arm and leg for the repair. I don't have any images to show....
  • 1 more comment
  • sergio vivas Apr 10, 2008
    me gustaria sabar cual es el numero de parte de la cajita de de cuatro lado ( tunel de luz ) el modelo es infocus lp 600
  • razmig Apr 27, 2008
    We had this problem. The nearest repairer is 200 km away - three hours by road. The service agent would potentially have taken minimum two weeks to receive, repair and return. Instead my husband replaced our infocus lp600 light tunnel with a piece of 10mmx10mmx1.5mm aluminium channel inside which he placed a polished aluminium reflector panel from fluoresent light casing cut to fit and folded square. Three months later and we have no further problems.
  • fredb205 Oct 06, 2008
    i have the same problem. Is there a place we can get these mirrors replaced?
    Fred
Http://www.avsforum.com/avs-vb/showthread.php?t=795397
It's something that you can try yourself. Check the link and play with it if you want. =)
Posted on Mar 11, 2008
2004 Grand Jeep Cherokee Laredo electrical issues - Power Locks, Power Windows and Power Mirrors won't work
Power locks/windows/and mirrors, all have wiring connections within the door panels. Connections may be broken/unplugged. Check and spray electrical cleaner on the plugs internal parts. Also, main switch panels may be broken individually, but not likeley. Check all fuses that power these items.
Steering wheel noisy while turning may be worn steering bearing on shaft. Check and replace as needed.
Dec 16, 2015 | Jeep 2004 Grand Cherokee Laredo
Driver rearview mirror detached from its holder
Dismantle the mirror bracket. You probably wont be able to get this back in without doing this.
Mar 02, 2014 | 2006 Subaru Forester
We have an LP600 with a black fizzy edge slowly sliding into the image field from the left picture edge?
sounds like you have a broken light tunnel. Its just a four sided mirror that has a broken side.
Mar 10, 2010 | InFocus LP70+ Multimedia Projector
What parts do i need for a broken drivers side mirror
I believe you can't get the internal parts of the mirror head. you can only buy a new mirror (just the glass) or an entire mirror head assembly.
check out...
www.burcoinc.com
www.directauto.com
hope this helps
Mar 04, 2010 | 2007 Chevrolet Tahoe
2001 dodge Dakota Power Side Mirror internal Hinge broken. Can it be fixed or do I need to replaced the whole mirror assembly?
yes, your better off to replace the whole mirror,you can buy a used one at any salvege yard cheap.
Jan 24, 2010 | 2001 Dodge Dakota
I have a 5 year old RCA 61LPW42 HD DLP television. A few months ago a small dark shadow appeared in the upper left corner of the screen. Over time it has creeped down and become larger. Still starting...
It's the light tunnel. The tunnel is a square tube made up of 4 mirrors glued together.
It looks like this from the side: |_| (with a piece on top too.)
When the glue breaks down, it shifts inside the little mirror holder. The shifted mirrors looks like this /_/ what you are seeing is the shadow of the tilted mirror tunnel.
ON the RCA's there's not a good fix.
RCA's response:
"Ok, well sadly they do not offer the light tunnel anymore, which is what you need. Sadly you would be rendered to get a whole new light engine assembly. That would be the D.N.D module, light tunnel,color wheel,optic spanner, and oci. mirror. Your best bet would be to search ebay for a broken engine and replace it that ways."
That is the ONLY response I got from them.
I took the set apart and found the 4 tiny mirrors. I will be attempting to epoxy them together. (The set is dead anyway, why not try?)
Apr 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Well without seeing the damage I would have thought Superglue would be your answer and just re afix the mirror if it is indeed undamaged .
Otherwise as it has a working bulb ( usually worth more than the actual machine? ) Maybe a replacement unit off ebay can be obtained you would also have a spare for any other repairs . .... Regards Vortash
Feb 22, 2009 | InFocus LP 530 Multimedia Projector
How do i turn in my rear view mirrors
On drivers side internal door handle there's a small, joystick and an up-or-down switch. the former moves the mirror while the switch selects which mirror. good luck !
Oct 28, 2008 | 2001 BMW 3 Series
LP600 - Grainy picture, very poor quality
Single chip DLP projectors use a spinning color wheel between the lamp and the DMD (mirror chip) to produce colors. If the wheel rotation/synchronization is disturbed, colors will not be displayed correctly.
In my case it looks like the wheel became un-synchronized, probably because the projector was dusty/dirty inside (a light senor is used to detect the wheel position), resulting in a grainy, slightly flickering image.
I simply blew out the components with a can of 'Dust-off' and, using a small tool, rotated the color wheel by hand to make sue it wasn't rubbing or jammed.
I reassembled & started the projector and the image was back to normal.
Jul 19, 2008 | InFocus LP 600 Multimedia Projector
Small bluish, black triangle at far right corner
This is the same problem as other posts have mentioned about the right side of the screen having a bluish-balck stripe down the side of the screen. Here's what's happening. There's a small light tunnel which has 4 very small mirrors located just behind the color wheel. The lamp shines light through the color wheel as it turns and the light goes through this small tunnel and is then relected off several mirrors before it is projected through the lens and onto the screen. Optoma apparently did not use a very good heat resistant expoxy glue when they assembled these mirrors and over time the mirrors drop down causing a shadow effect on the screen. It can be repaired without paying some repair shop a small fortune. Previous posts have a solution from another contributer whihc includes photos. I had to repair mine and it's worked fine since I used a decent expoxy to hold the mirrors.
Sep 28, 2007 | Optoma RD65 65" Rear Projection HDTV
InFocus LP 600 Multimedia Projector Logo
812 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
