Example: March 15, 2008, 10:30 AM 1. Press [CA] 2. Press [TIME] 3. Hold down [%] for about 2 seconds 4. Press 103003152008 5. Press [TIME] 6. Press [TIME]
Place the tape between the two posts; then put back portion of cover down followed by the removal front portion - press feed button and it should feed. Remember it will only print on thermal paper ----
Simply place the paper between the plastic posts. Put top portion down; feed paper up slightly - put smaller front plate back in place and press feed button.
Hit time then hit set hold down for about 2 seconds (% key) then change the time hour, minutes it will change back to date but if you just hit CA button the time will be set
I have a model DR-T120 maybe it works the same way.
press
CA
TIME
% (hold for about 2 sec)
"enter date and time"
Note( any time during setting procedure you can press = to cycle date format mm-dd-yyy, dd-mm-yyy, yyy-mm-dd)
TIME
Hope this Helps.
Rick
