Question about Microsoft Xbox 360 Console
Xbox keeps shutting off
My xbox keeps shutting off. I have to keep reseting the red button on the power cord. It will turn off in the midle of a game
    Genius:
  • 1,019 Answers
Overheating problem, view the XBOX 360 forums, you,ll find answers there for your problem.
Mike @ compurepair.
Posted on Feb 24, 2008
Why does it keep shutting down after 5 min of playing a game?
Xbox Keeps Turning Off - Xbox 360 S - iFixit
https://www.ifixit.com/Answers/View/.../Xbox+Keeps+Turning+Off
iFixitI put up with it turning off of a couple of weeks and then the power cord blew up ... The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. ... After your description, I am starting to think that your power brick is the problem. .... in i cant donothing about if i was trying to play my gta4 in keep cutting off in 1 ...
Does Your Xbox 360 Keep Freezing? ' MyGamerXP
www.mygamerxp.com/xbox/does-your-xbox-360-keep-freezing/
Sep 14, 2015 - 5. Check Your Xbox 360 Hard Drive. Not only can the cache corrupt from .... I unplugged the console when it froze instead of turning the power off. ... hi my 360 keeps on freezing on any game i play and like the screen frezzes but .... It willnot, even after 6 goes, play, it freezes, and after about 2 mins, it ejects.
My 250GB Slim keeps turning itself off every 5 - 10 minutes ...
forums.xbox.com/xbox_support/f/7/t/156970.aspx
Xbox
Jan 17, 2016 | Video Game Consoles & Games
Were is the reset button to completely whipe the xbox because it keeps saying that we need to re put the disck and we did but it didnt work
There is no reset button unfortunetly. The best thing you can do is go into the settings and tell it to rreset to factory defaults. And if you asking for a reset button because the console wont shut off, them just unplug the power cord.
Apr 14, 2011 | Microsoft Xbox 360 Console
Xbox consol has red ring only 3 lines not full ring
This could be a mjor problem.. Kindly Check this picture here for reference..
Or, you could try doing there simple troubleshooting steps:
  1. Restart the console.
  2. If this did not work, there could be a loose cord or cable. First, any cables and power cords that can be removed should be disconnected. Unplug the power cable from the wall plug. Firmly reattach all cables and cords back into the console. Now connect up the power and turn on the console.
  3. If the above step didn't work, then try turning off the console, unplugging the power and then disconnecting the hard drive. Now plug into the power and turn the console back on. If console does not show the three red lights error, turn it off and disconnect the power cord from the wall. Finally, reconnect the hard drive, plug in the power, and turn on the console.
  4. If you are using a defective surge protector, plug strip, or extension cord, your xbox may not be getting adequate power. Try plugging the power brick directly into the wall. This sort of thing happens more often than you might think. My DSL connection used to be very unreliable until I bypassed my surge protector and plugged my modem directly into the wall. I should have done this in the first place rather than making a lot of angry (and useless) phone calls to my internet service provider.
  5. If you think that your machine has overheated, then turn it off and let it cool down. Ensure that the cooling vents are not blocked in any way and keep your Xbox 360 in a ventilated and open area.
    Do not place near it any sources of heat. There are obvious sources like heaters and radiators and such. But less obvious sources include the electrical devices that are sitting on top or beneath your xbox.
    Try removing any dust buildup inside the machine.
    Cool off your console with a small fan.
    Don't forget to keep the power brick cool, so keep it off of shaggy carpeting. Better still, place it on an elevated surface. You can even hang the power brick by its cord off of a hook.
    Keep the rear of the console clear. Don't push it up against a wall and keep any debris away. This includes not allowing any cords and cables to get all bunched up in this area.
    Don't do any all day gaming marathons. Limit your gaming to just a few hours, then turn it off and let it cool down for a while. The warmer the room temperature is the shorter your playing time should be.
if all else fails, consider of having your XBOX repaired by a local tech or the nearest XBOX service center. this could be a little expensive but a quicker option..
Mar 16, 2011 | Microsoft Xbox 360 Console
1) The Xbox was unswitched and then turned on again, there is now no power to the X Box at all. 2) One of the handset connections is lose as well and a part seems to be missing.
The (old) xbox should boot up without any controllers and without any disc in the drive. If you get no lights at all on on the front panel, check the power cord to be sure it's connected.
Some original xboxes had a circuit breaker in the power cord. The plug is large and has a yellow and red button on it. If this is present, check to see if the breaker needs to be reset. If it keeps blowing, then your power supply needs to be replaced.
If this is an xbox 360, then you entered your product incorrectly. You may want to open a new request here.
May 17, 2010 | Microsoft Xbox Console
Xbox keep turning off power cord light turns red
the problem is your power supply is overheating you just have to keep it in a area that is cooler or has less heat . the best bet would be turn off your xbox let thepower supply cool down and then turn it back on . you might need a replacement the same thing happend to me
Sep 23, 2009 | Microsoft Xbox 360 Console
Xbox flashing red around the on button. screen is in chinesse says contact support. not loading. number E74 on the bottom of screen.
Hi, power off xbox remove av cord from back power up unit.. After a couple minutes the xbox will shut down by itself once it does Put the av cord back in and power up.. Good Luck
Jun 30, 2008 | Video Game Consoles & Games
My xbox360 has 3 flashing red and will not respond to anything except turning the unit on off and opening and shutting
turn off xbox, unplug the av cord from back of xbox.. power up unit without av cord.. wait til unit shuts off by itself.. reattach the av cord and turn it on..
My xbox 360 has one flashing red light, and it keeps showing me the code E 74
Jun 29, 2008 | Video Game Consoles & Games
XBox 360 power problem
The power brick has most likely died.
Dec 14, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
243 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
